st4nd4l0n3
The first rc car my brother had when he was a kid was the Kyosho RAIDER. Ever since, he's been a little bit of a Kyosho fan.
When the RockForce came out it didn't get very good reviews (to put it mildly). So my bro decided to make a comp crawler out of it, but keeping at the same time all of the RF's original attributes, like the Panhard bar, the stock worms, or the kyosho dig system.
This is the result of his personal vendetta:
RF-V4Vendetta EVO3 (Made for the RockForce 2.2)
SPECS:
Measurements
-Wheelbase: 310 mm
-Track width: 270 mm
-Height: 140mm-190mm
-Ground Clearance: 32mm-82mm
-Weight: 2440g (without battery)
Chassis
-TVP:Nylotron 6mm (CNC Custom made)
-Skid plate: 8mm delrin (CNC Custom made)
-Links delrin 8mm (CNC Custom made)
-weight: 149gr
Transmission
-Ratio: 143.33/1
-SPUR GEAR stock 86T
-Dig (kyosho No.RFW001).
Axles
-RF axles (stock worm gears)
Axle ratio: 30/1
Suspension
-Panhard (Front), 4links (Rear)
·90mm F
·120mm R
-Rod ends:Stock (6mm)
-Shocks:
·Stock shocks
·Springs: kyosho 1609 Soft White
·Silicone Shock Fluid 050
Wheels
-Rims:2.2 M.I.R
-Tyres: HB Rovers (white)
-Foam: Panther Memory foam
Motor:
-Novak 18.5t ballistic crawler edition 3s
Electronics
-ESC: Novak goat crawler
-Steering servo:hi-tec hs-7950-ti
-Radio: traxxas 4ch (27-mhz)
-BEC:3-Amp Novak High Voltage(# 5463)
-Batery: lipo 3s 2850mh 40c
A few pics
The only verdict is vengeance; a vendetta, held as a votive, not in vain, for the value and veracity of such shall one day vindicate the vigilant and the virtuous.
SPECS:
Measurements
-Wheelbase: 310 mm
Chassis
-weight: 149gr
Transmission
-Ratio: 143.33/1
Axles
Axle ratio: 30/1
Suspension
·90mm F
·120mm R
-Shocks:
·Stock shocks
Wheels
-Rims:2.2 M.I.R
Motor:
Electronics
A few pics
