BlackSeaRC
The body on the Katana makes the Axial bodies look like something from a cheap toy!
Hi can anyone tell me how can I disable the turn signal of this Katana? It is driving me nuts. You don’t have to indicate while off roading. Thanks.
I like the headlight but not the turn signal.
Hi - simply pull out the wires (connected to ch 1).
Emm.. sorry not very electronic minded. If I pull out the big 3 wires connector them the main light come on permanently, turn signal still on.
Not sure hot to find which wire is for the turn signal control. ?
Maybe I'm wrong but I think you'll have to take the body off to do that. The only connector on the stock receiver (at least on my Katana) is the steering servo.
You could do one of two things but either case, you have to remove the body with all the screws from the bottom. Once you have the body off, you can simple cut one wire going to each of the turn signal while capping off that cut wire with tape or a tiny wire nut connector (simply to keep a potential short from occurring). Or if you want to get fancy and experiment with a soldering iron, you could solder the turn signal wires to the same leads that go to the head lights. This way all the lights will light with headlights/taillights via Ch 3 on the Tx.
I too am not a fan of the turn signals so I plan to do one or the other myself.
....I like the idea of linking the orange light to the main light, maybe paint them yellow like fog light.......
Actually I don't thing that will work after I played around with mine. I tried using the "Y" connector to connect the turn signal lead to the headlights. The turn signals blinked and only one side lit up. Once you turn the on and off the lights (Ch 3 ) the other side comes on and blinks. So I'm thinking there's a blinking relay in there somewhere. If you find it and eliminate it you may be able to do that.
Perhaps the way they are wired? Or maybe even the transmitter has a flashing mode? I honestly don't remember I haven't had time for my RCs in a whileAnyone have issues with the roof light blinking? I wired up some LEDs for the roof which were working fine for a while. Now they're blinking... Checking the ESC, the roof light pins arealternating between 0V and 6V. Not sure what happened...
