Ridgecrest Problem
cwoods333
Peru
I have a stock ridgecrest with only about an hour on it. I have lost the front wheel drive. I don't know what to start with to try an fix it.
The trans needs to come out and apart. Right out of the box most RTR rigs need to have all screws checked...........
In the trans, the two output shafts are attached to the big gear. These screws are known to be loose or come loose......they can back out far enough to separate one or the other output causing 2wd.
Buy new M3 screws to replace all of the coarse screws and all headaches should go away for you.
Have fun.
