Hi guys I was lucky enough to get my new riddler x last week from hulksta engineering so I began straight away .
The biggest difference with the new riddler is way the feature shock works compared to the v1 riddler I don't have to run the spring anywhere near as hard as I did with the v1 and shock oil so much thinner whilst still retaining the about the same amount of opening . the shock actually works like a shock now and with adjustable preload it's a hell of a lot better.
Chassis :Riddler X blue carbon edition
With all 3D printed part options ( haven't arrived yet )
5th shock : trf 55mm with d3 cap and a 1.9 wire spring (still playing with oil)
Ally and tittianium hardware through out
Shocks front : scx .losi mini t rears silver 35 wt
Shocks rear : scx Rc bros springs 45 wt
Tittianium links : Mr Links riddler links
Blue rpm rod ends and traxxas ally balls
Axles :
dlux super lights : fully rebuilt
Delrin centres ,Delrin tubes ofna unis and 7075 8mm rear shafts 7075 lockers .
Gears : are a mixture dlux reduction gears
, Rcbros, Rc4wd
Knuckles : dlux delrin knuckles
Knuckle weight: home made carbon fibre tungsten slug holders run low and to fit a 2piece rim
Chubs : axial ax10
Wheels and tyres : herc team rims with gold dot voodoos
Electrics :
Servo : hitec 7980
Esc: HH brxl minis
Bec: castle 10amp at 7.8 volts
Motors : brood 40t Stubbys
Big thanks to my sponsors for all the support
Hulksta engineering
Mr Links
Jaycuts
So first things first I changed out the s/s hardware for purple ally saved almost 20g then set about the fifth shock
The shock is a tamiya trf with a d3 cap traxxas ally balls a 2mm wire spring and at the moment a mix a few drops of 5000 wt oil and the rest 100 wt oil seems about right
So last night I fully rebuilt my super lights
New front carbon gearbox plates
New bearings front and rear new tubes front and rear cleaned and re greased
Sitting pretty
Today my 3D printed chassis bits arrived
Saved a couple of grams
More to do but getting there
Axles :
, Rcbros, Rc4wd
Chubs : axial ax10
Electrics :
Servo : hitec 7980
Esc: HH brxl minis
Hulksta engineering
Mr Links
Jaycuts
Sitting pretty
