Hulksta
Also visit.... http://bevear.wix.com/hulkstaengineeringrc
UPDATE
As of September 2015 all chassis going out will be of the new updated twin shock design. I listened to my customers wanting an scx10 to fit and to get elec's into the guts of the chassis so here it is and it looks bad arse too!!
The new design now allows the chassis to accept a stock scx10 shock size and will now be a lot easier to tune...
Now you can put oil in one for dampening run the other one dry with an internal spring (pulls the feature closed) this will make it a faster process to tune and cleaner as you can swap the spring without having to deal with the oil... Or if you really wanted you could run oil and spring in both, or two different rate springs.
An added bonus is you now have more room in the guts for the elec's
Shocks not included.
No price change with the upgrade "thumbsup"
First pic is of the new upgraded chassis!
Hi Guys,
Time to change things up in PRO :twisted:
I've been wanting to build this for some time, had the idea in my head for so long about a chassis that has a low cog BUT can give awesome clearance without changing too much of the tuning etc they we all know.
At first i was thinking of using a servo and forcing the front down.. some issues though was 1.added weight 2.extra radio function 3.a real time killer.
One key feature i really wanted was for it to act fast and not slow my pace at comps..... so i though more of how do i achieve this? so i turned to something i know "shocks" and it was meant to be!!
The shock is fast and doesn't add to much weight, and the big thing is it works independently to everything else so you can focus on just driving! You can also tune it to your liking with different springs and oil's.
Hows it work?
Basically its an extension of the front shocks, as the belly of your rig is on a breakover it allows upto 40mm extra clearance... it doesn't affect the links it just controls the height of the front shocks.
Now you dont need to use the feature either ;-) If you like the look and just want to use as a normal chassis then there are holes in the side to "lockout" the feature and it then works as a normal chassis... This option also allows you to lockout the feature when tuning your main shocks.
On top of the 5th member feature this chassis was built with strength in mind, its made from good quality carbon fibre and detailed in solidworks to make sure it can take a beating... it is also builder friendly, the design was worked in such a way that you could use straight upper links (ive got bent fronts in mine but that is just to give me batt room)
I'll add more info etc as the questions progress :mrgreen:
Cost for a built chassis $180aud
International postage tracked to most country's $22aud
Local Australian registered postage $11aud
Paypal is.... bevear@westnet.com.au
Please msg when making payment your RCC user name so I have a contact incase I need to.
It comes...
Assembled with alloy hardware, bearings for the feature, carbon side plates to keep to rig in spec (it was built to the letter of the rules)
Chassis doesn't come with a shock for the feature, you with need to add your own shock and tuning... or use screws in the side holes to lock out the feature.
Links???
I have a link guy that is now making links for me, if you order with links he will make and ship to me then i ship with the chassis & tracking.
Titanium links @ $130aud set of 8.
Stainless Steel links @ $75aud a set of 8 links
No rodends (he can supply if needed) in lengths you request... He is set to make XR10, Dlux/Berg and Bully2 sets ready to bolt in!
Now I'll shut up and leave you with some PRO porn!!
Video!
https://www.youtube.com/watch?v=mDdIkbo8rJ0
https://www.youtube.com/watch?v=WqFPA0NSrs4
https://www.youtube.com/watch?v=aQNsTXMueKY
https://www.youtube.com/watch?v=nBTj2LpDqBU
UPDATE
Hi Guys,
Hows it work?
It comes...
Links???
Video!
