Reverse secondary CH1 only on Traxxas TQi?
Goro Majima
Subscribed Member
NorCal
I have finished mounting a steering wheel servo under a dashboard for my LC80 TRX4 build but unfortunately the position is backwards and is opposite of the main servo direction. Is there a way to reverse that secondary channel 1 only instead of reversing both channels? Thanks all.
I believe it's the same output sent to two connectors, so you'll need a servo reverser. I've seen some YT videos that explain reversing servos internally, maybe you can do that. Anyway, don't think you can do it on the radio.
Yeah, the servo is way too small for me to even attempt to swap wires around so servo reverser it is. Thanks y'all.
