Mysterious
Hey everyone,
I could use some motor advice. I’m not all that knowledgeable when it comes down to the electronics despite being in RC hobbies a long time with all kinds of vehicles in the air and on the ground. Generally lean on my friends for advice on what to get. Many moons ago I built an XR10… here's the actual build thread from that if you're interested...
http://www.rccrawler.com/forum/axial-xr10/415674-mysterious-switch-slow-build-thread.html
I've used it sparingly over the last decade but one of the motors just pooched on me. It gets hot and won’t go til you give it of a bump. My friend broke it down and checked it out and he said it needs replacing. So I'm looking at buying a new matched pair of motors to install.
When I originally built this I put on Team Brood Apocalypse with these components....
Apocalypse
Options:
Wind and Armature: 45 Turn Type SR (+$10.00)
Armature Upgrades: Dye
Balance: Drill (Standard)
Comm Size: 7.5mm (Small)
Brush Configuration: Laydown (Standard)
Brush: Stock
Springs: Purple 9oz Heavy (Standard)
Lightweight: Stock
Bearings: Steel ABEC 7 Bearings
Matched: Yes (Quanity Must Be Two)
Timing: 6
Rotation: Normal
Vehicle: XR10
So I was thinking about either getting another set of Apocalypse with the same components (even though you can only indicate the wind, timing, and rotation now):
https://teambrood.net/product/apocalypse/
OR…
A friend of mine suggested I look at Holmes hobbies... and I came across these TORQUEMASTER PRO 540 45T motors which look comparable.
https://holmeshobbies.com/motors/br...ster-pro-series/torquemaster-pro-540-45t.html
Which set would you guys suggest is better? Or do you have an alternate that you would suggest? :?:
I crawl for fun not in competition, though as you can tell I spent a lot on building this crawler cause I wanted something that was very capable so I'm looking to put quality motors. I run 3S & want to stick with 45T FYI.
Thanks in advance for any replies. "thumbsup"
Apocalypse
Options:
Brush: Stock
Lightweight: Stock
Timing: 6
Rotation: Normal
Vehicle: XR10
OR…
