removing water base paint
infamouse_1
GUAM
What is the fastest way to removing water base paint? I used createx paint and it reacted and now I got some fish eyes on the body! :( I want to remove it without having to work hard!
if it is a hard body I've always used yellow top easy off oven cleaner. Spray it on and leave over night and wash off with a water hose with good water pressure
water base
I would use easy off but don't want to harm the primer, so I picked up paint thinner and I just used a cloth to wipe up as much as I could off the body :) but another question?? Will enamel or acrylic paint react to water base paint??
I got problems with water paint reacting and cracking due acrylic paint, but never saw the other way.
VERY hot water in a bathtub will remove it, it needs to be extremely hot and you let the body sit in the tub for a long time. Adding a small amount of IsoPropyl alcohol will also help.
thanks
Thanks guys for the help!! But found a easy way out of it wet sanding is a lot easy! :) and I kinda like water base paint cause no matter how much you run it will settle it self out ill be posting some pics soon of the finish paint job on my yota
paint
Yea I red the same post here on rcc,but a week for it to come of that's a bit to long, you think so I just went ahead and gave the body a wet sand came out pretty good paint is almost done ill be posting pics real soon!!
