King Dork is correct, the micro x crawler is rated for a 2700kv puller pro or 2850kv castle slate. I’ve ran the 2850 with a micro in idk 4 or 5 different rigs including a 7.2lb 6x6 and have no complaints. Other than the bec which isn’t an issue with a direct power servo
If I run a direct power servo would that take a little of the load off the esc?
Yes, because it’s not relying on getting its power from the esc through the receiver. Also takes a large load off the receiver. You could always run a standard servo, but with the micro x you definitely need a bec
I forgot to include the dig, I should probably run that off a direct power as well. Or maybe a micro?
What transmission are you running? That’s a good question, I’ve never dealt with dig and a micro x. Maybe someone else can chime in but I think you would be fine considering how little use it gets compared to the steering servo
