fyrstormer
(reposted in the SCX10 subforum because the AX2 transmission also fits the SCX10)
Several years after buying my Wraith and installing a RC4WD AX2 transmission in it, I finally decided to modify it to reduce the slop in the shifter assembly. Here's what I came up with:
I bought a piece of 4mm solid brass rod, cut some pieces off it, epoxied them into the slots on the sides of the gears, and then sanded the sides of the gears smooth so there would be no protruding edges for the shift puck to get stuck on and rip the brass inserts loose. (not that I don't trust the strength of JB Weld, but why tempt fate?) I could've gone further and filled-in the other side of each slot as well, but I would've needed to grind away some of the round profile of each brass insert to leave enough room for the shift puck to engage properly, and I just didn't care that much...this time around. ;-) Maybe next time I have to take this transmission apart, I'll finish the job.
Hope this helps someone.
