When I got the Wraith, I was unsure what direction I wanted to go with it, Scaler, Crawler, Rock Racer, etc. It made it even more difficult when upgrades started hitting the streets.
What I figured I would do is take a stock RTR Wraith and build it in stages.
My hope is that someone that just bought a Wraith can use this as a guide to what they want to do with theirs.
I am starting with a Stock Axial Wraith RTR
So Let's Begin:
First thing was to remove the wheels/tires. At this point I started working on the front.
The Wraith sits pretty high so to lower it as much as possible, I flipped the link mounts on the axle. As you can see in this picture, it will make a difference of about 1/2".
To lower it even more, you can go with a shorter shock...that will be at a later Stage.
The unique thing about the design of the Wraith is that the upper links look more like the lower links that we are used to. (OEM on the bottom)
Here are the lower links:
The XR-10 Upgrade Kit also works on the Wraith Front Axles. The rear adapter is too short.
While adding the Alum Knuckles and Chubs, I decided to gain a little extra steering out of it. I installed a set of the XVD's. These will give you all the steering you will ever want. And being that this is not going to be a race rig, they should give me what I need.
Here are some comparisons of the stock steering and what the XVDs and Knuckle Upgrade give.
Anytime you are doing mods to your rig, you have to add some bling...so here are my ARB Diff Covers.
Can you say BA-BLING?
Now installing the ARB Covers, due to the detail, you need to flip the Locker or the ARB will be upside down.
This is a really easy process and I want to thank Axial for thinking this through. All you need to do is pull the shafts out, remove the cover, remove the 4 screws holding the locker in.
Pull the Locker out and flip it.
Put it back in and replace the retainers and four screws.
Mount everything back up. Make sure it's all thread locked, if needed and tight.
Put the Wheels/Tires back on...
NOTE: you will need to either reverse your throttle channel or reprogram your ESC due to the fact that you flipped the Lockers.
STAGE 1 Complete!!!
So Let's Begin:
STAGE 1
Materials:
Integy V12 45T Motor
RC4WD Aluminum Upper Links
RC4WD Aluminum Lower Links
RC4WD XVD's
RC4WD ARB Diff Covers
Axial XR10 Stage 1 Aluminum Upgrade Kit
Materials:
RC4WD XVD's
STAGE 1 Complete!!!
