RcBros Brass Burly Tube Giveaway
RcBro
RcBros Hobbies
Vendor
Oregon
RcBros Hobbies 1.9 Scale Rig Giveaway
No axle is complete without our Burly splined tube set. Our Burly tubes have several benefits that you just simply can’t be without.
The plastic housings are not known to be the strongest on the market, add a good steering servo and a little bit of time, you’ll quickly find yourself snapping housings left and right. Not only do our Brass tubes fix this issue, you receive the added benefit of the Splined extension allowing you to run all the aftermarket XR10 and Wraith components.
Take advantage of the extreme steering angle, adjustable caster and aftermarket accessories that our Burly Tubes give you!
Rules:
* Must be a star holding member
* Post one time
Winner will be chosen April 8th!
