RC4WD Mojave 4 door body?
Efrazler
Greer
Looking to buy an Element Enduro RTR and just switch the bodies for now. I have two main questions,
1) Is the wheelbase adjustable on the rtr version?
2) Will the mojave 4 door body even fit on this chassis? (mainly concerned with width)
Thanks everyone! "thumbsup"
Wheelbase is adjustable, but new rear links are needed to change the RTR (Builder's Kit comes with them).
However, the stock RTR wheelbase is 12.3", which is the same wheelbase as a RC4WD Trail Finder 2 LWB 4door.
You will have problems running an interior because the battery tray is much more forward on the Enduro chassis vs the RC4WD chassis and the motor/transmission unit is also centered in the Enduro chassis instead of the front motor/transmission/low-mid-mounted transfer case of the RC4WD.
Thanks for the info! Tried to research if these are compatible for about 3 hours last night and came up with nothing, should've known all It would take is a post in these forums. "thumbsup"
