BIGW0RM
RC4WD Gelande II 1/18 Motor upgrade!
Hey all. I found a way to mount a F 050 long can motor to the stock transmission!!!
RC4WD puts a motor spacer/mount on there small motor that you can remove and FLIP over (so the holes mount up) to use on long can motors which seem to have the mount holes the other way.
I used a stock ecx barrage long can with the stock motor mount flipped and that allowed me to install the ecx barrage motor exactly like the stock 030 motor!
It fits perfectly and even with the bigger pinion the ecx motor came with, you still have plenty of torque and A LOT more speed. You will have to drill a small hole where the pinion is for clearance. And I’d use my stock pinion off the small motor but mine blew up and that’s how I figured this out.
I feel like I have 20-30% more power with the long can motor and I think a 12t pinion that the barrage motor came with.
Hopes this helps the few who have a mini RC4WD.
I can still climb all the home made obstacles just fine. And others that I could not climb, I can now with the extra wheel speed.
Link to the motor with 12T pinion installed.
https://www.ebay.com/p/Dynamite-Mot...e-DYNS1203/23011724025?_trksid=p2047675.l2644
