DRED805
Business in the front, party in the back!
CURRENT PARTS LIST:
Brazin ATL V2 Flat Rail Aluminum Chassis
VFD Transmission (standard 6% OD)
VFD Dig
In The Works SCX10 III Gladiator 13.9" Wheelbase High Clearance Titanium Links
Vanquish F9 Pro Front Axle (vanquish underdrive diff gears)
SSD Heavy Knuckles (to help match rear weight)
KYX SCX10 III Metal Rear Axle (reverse cut diff gears, 14/21 OD portal gears)
GSpeed LayDown Servo Mount
Protek 170TBL Servo
Brazin Aluminum Panhard Mount
RC4WD 67mm Titanium Links (chassis spacers)
Incision 90mm Shocks
SSD TRX-4/SCX10 II Kit Rear Driveshaft
Incision SCX10 II Front Driveshaft
Incision 1.9" Method MR307 Wheels
RC4WD 4.70"x1.87" Goodyear MT/R Tires
Crawler Innovations 4.50" Comp Cut Inner / Soft Outer Foams
Mamba X ESC
3Bros ACIS TEN 1600kv Motor
Spektrum SR315 Receiver
IERC Power Wagon Back Half Aluminum Sliders
NSDRC RS100 Micro Servo (dig)
Spare-Time Hobbies Hurtz Dig Compact Micro Shifter Mount
J Concepts Tucked F250 body
2x Tattu 850mah 3s Batteries (6s)
The rear links are comically long, but it'll be fun to see how it ends up. I went with a portal rear to help give them a little more clearance as well. It's definitely gonna take some tweaking to get the mishmash of parts to work together. For instance I need to lengthen the front upper link to get the right pinion angle, and clearance the skid plate so I can flip the lower links to the correct position while slammed. Getting the panhard worked out will be the next headache.
Gearing is a bit extreme as it sits. Even with the underdrive front diff and overdrive rear diff, the portal still puts it at roughly 48% overdrive overall. I already had those differentials for another vehicle, so I'm just gonna run them and see. If it's too much, I'll put one of the diffs to stock, and get the ssd portal overdrive gears to make it roughly 28% overdrive.
I've got pretty much all the parts to finish it, but I'm in no rush. I'll update the parts list as I go. Please feel free to give me any suggestions, or point out any issues I might be missing. Thanks for checking it out!
CURRENT PARTS LIST:
VFD Dig
Protek 170TBL Servo
Mamba X ESC
