tjb
For years I've been doing baked on enamel finishes on small parts, more to speed drytime than anything. I have been using Krylon Fusion for the past couple of projects. The durability is as close to powder coating as you can get for a painted part. I've had a helluva time taking it back off to add more tubes on a bumper I have done this way with Fusion. The rock guards on my Blazer scaler are done with this and have seen some good rock rubbing and there is no bare metal as of yet.
The key is a very clean part. Heat oven to 325-400 (lower the temp, longer the time). Paint the part as you normally would. You can either put the part in wet, or let the paint tack up a bit. Hang the part as high as you can get it in the oven, I normally use the broiler element or put a rack on the very top slot if the part is small. I have found that placing a piece of foil below the part keeps the direct heat from the element off the part a bit better for a more even baking. Run the part for 45min-1hr, and either pull it out and air cool it of just shut the oven down and let it slow cool. I don't think it makes too much difference, I've done both.
*If the part was brazed, make sure all of the flux residue is off, if it is not it will cause the paint to bubble/fisheye........ Also keep to the lower temps when using aluminum
As far as the smell when baking, Fushion is about the best, and has very little, to no smell to it. In the past I mostly used Rustolium and it is rather strong smelling when used.
Fushion leaves no after smell when dried this way, so you should be OK with the wife "thumbsup"
I have mainly used Gloss and satin black. The satin comes out more of a semi-gloss/gloss than a flat black
If you try a toaster oven, I can't know how it will work, I have not ever tried it with one yet..
