MattySlimz1987
So today I hooked up the Castle Link to change the throttle percentage down or the startup speed because after a short full throttle pull, I did a finger test through the rolled down window on the body I'm using and it was unusually warm. I did a full throttle run for about 20 yards out and 20 yards back. The motor is a PP 2700 standard and was ran on 3s. Esc is a Mamba x. When I originally installed this motor and controller it was with the prior firmware from Castle which I believe was version 1.82 and I set the power to 90% figuring that would be all I need and would be in the safe zone. Also set the start-up speed to Medium. When update 2.02 came out, I left everything the same and just changed to the new feature of race/rock mode. Mr. John Holmes' website states the PP"s max rpm is 50,000. Now tonight when I go to adjust the settings I decided to download and veiw the data log. Low and behold there it was, I saw that the motor rpm went all the way to 62,000!! Now I know these motors (especially 4 pole sensored) were designed for smooth technical crawling but also for rock racing, so I'm hoping no damage was done. The other sensorless motors I have in bashers get hot, but I'm not as much worried about them because they have blowers wrapped over most of them and are 2 pole sensorless. This one I'm more concerned about.
As you can see on the data graph, they were only about 3 short burst's and the motor wasn't very hot, I could keep my finger pressed hard on the can for a longtime without having to back away. Temperature in the area on this beautiful Easter afternoon was a mere 76 to 79 degrees. Everything seemed fine afterwards, smooth crawl, no weird noises, just hoping no damage was done to the stator or anything else in there. Set the level down to 60% now as thats all I need and so that this doesn't happen again!
*note: Temperature is the esc shown, temp for the motor is only logged while in "sensored only" mode. My setting is SmartSense mode. Graph indicates readings that are set at 1 per every 2 seconds.
Only info I could find was here::
Originally posted by John Rob Holmes from this thread. HH Puller Pro 3500kv standard owners? - RCCrawler
"The voltage recommendation doesn't max out the motors. 3500kv will take 4s, 2700 will take 5s, 2200kv 6s. But systems get finicky and easy to destroy without very detailed testing at those voltages. Possible, but not generally recommended."
Any other experience/suggestions on settings or info about if the motor is ok would be greatly appreciated. Also do you believe this information the log is giving me is accurate? The temp noted for the esc on start up says 24 degrees Fahrenheit... it was almost 80 degees out today.. has me questioning the accuracy of the data it collects..
Thanks!
Thanks!
