OSRC
Sorry, I disagree. As of right now, it's not easily fixed. It's sloppy in general, and has terrible bump steer. Mounting the servo rigidly and offset in the chassis and 4 linking the front axle is never going to work out well. Either the servo should be on the axle or the axle should have a panhard. Mine's never even been run yet and it has a good amount of slop. After some running, it'll be as bad or worse than the '01. I can certainly modify it, and I'm sure I will eventually, but frankly I'm very disappointed.
There's zero reasons for it... Tamiya's engineers couldn't come up with something better? I understand it's not a pro crawler - I never expected it to be. This is Tamiya we're talking about... home of the Comical Hornet, Wild Willy, Kumamann DT02 and the funky trike thing. But it's also home to the Bruiser with an amazing transmission, The amazing Avante and countless TRF touring kits. So I know there's excellent engineering to be had. It's like there are 2 separate divisions, and they are not allowed to interact!
In any case, how this kit got out the door with it's overly complicated chassis, glue on parts and craptastic steering design I'll never know. It's like they took a CR01, made it 2x more complicated, ruined the geometry, shrunk it down to 1/10 size, and called it good. I expected better. Based on the fact that so far, krapulax and Matteo are the only 2 I've seen build threads, videos, or any activity on, I'm guessing word got out and I'm not the only one being critical.
Ok, I've ranted enough. Time to go wrench on something.
BTW krapulax - Start a thread and post some pics! Very curious to to see your portal setup!
