m0nster
I've decided to start a little write up on my new servo.
the brand is OMG (only manufacture golden)
Its a new smaller company, mainly started with helicopter servos, but now has a full line of high end surface options as well.
the servo I have is their brand new D3-ST-BF30S
Brushless, waterproof, HV, full aluminum case, titanium and stainless gears.
450oz @ .11 on 7.4v!
the packaging was very nice. included a small sticker sheet, 2 aluminum servo horns, and a pretty hefty plastic horn.
sofar from running around my backyard test area i am very impressed.
very quiet, compared to others I've used. almost no heat, SMOOTH, and very fast.
I have it pictured here on an axle mount, and on the Dlux sporty front truss.
specs are as follows:
Feature:
For: 1/10 Drift Car/ 1/8 th Buggies/ Crawler/ Trucks/ 200cc+ large scale airplanes
Material: Aluminum
Color: Silver/ Grey
Super high 12 bit (4096) resolution
Robust output for superb response in extreme maneuvers
Zero dead band assures legendary precision
Full Aluminum case helps dissipate heat
Digital precision provides great accuracy and performance
Ball bearing-supported output 25T shaft
Compatible with all types of Radio system
Pulse width travel is adjustable
Specification:
Operating Voltage Range: 4.8-7.4Volts DC
Bushing or Bearing: Bearing
Bearing Type: Dual Ball Bearings
Speed (s/60°@6.0V/7.4V): 0. 14/ 0.11
Torque oz./in. (6.0V/7.4V): 372/450
Torque kg./cm. (6.0V/7.4V): 26.8/32.4
Size in Inches: 1.57 x 0.79 x 1.54
Size in Millimeters: 40 x 20 x 39
Weight oz: 2.54
Weight g: 72
Motor Type: Brushless motor
Control System: +Pulse Width Control 1500µsec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Temperature Range(F): 14° - 122°
Operating Temperature Range(℃): -10° - 50°
Idle Current (@6.0V/7.4V): 4mA/5mA
No Load Running Current (6.0V/7.4V): 180mA/220mA
Stall Current (6.0V/7.4V): 3800mA/4700mA
Dead Band Width: 2µs
Potentiometer Type: Rotating(Max.220°)
Connector Wire Length: 11.8 in. / 300 mm. OMG wire
Connector Wire Gauge: 22 AWG
Connector Type: JR
Gear Type: Titanium gears+ Stainless Gears
Frequency: 330Hz
Shaft: 5.90mm 25T
Feature:
Material: Aluminum
Color: Silver/ Grey
Specification:
Weight oz: 2.54
Weight g: 72
Connector Type: JR
Frequency: 330Hz
Shaft: 5.90mm 25T
