THE OFFICIAL
CRAWLAPALOOZA 2018
INFORMATION POST
RULES ARE POSTED PLEASE READ!!!
PLEASE USE #crawlapalooza2018
THIS THREAD WILL BE PINNED AND UPDATED AS NEW INFORMATION IS AVAILABLE.
OCTOBER 5th - 7th
Disney, OK. Hogans Off Road Park
LIST OF EVENTS
FRIDAY:
2.2 SPORTY (upgrade)
2.2 PRO (upgrade)
SWAP MEET (included)
CONCOURSE (included)
NIGHT RUN (included)
SUMO TUG-O-WAR (included)
BALLOON BASH (included)
SATURDAY:
KOD (upgrade)
C2+ & C3+ SCALE COMP (upgrade)
POKER RUN (included)
SCALE ADVENTURER COURSE (included)
C2+ & C3+ HILL CLIMB (included)
SUNDAY:
C2+ & C3+ SLED PULL (included)
C2+ & C3+ MUD PIT (included)
C2+ & C3+ TANK TRAP (included)
______________________________________________
VEHICLE REQUIREMENTS ARE FOR SCALE COMP ONLY
CRAWLAPALOOZA 2018 RULES
Scale Comp Rules
Points
Progress -2
Reverse +1
Gate Marker +10
Rollover +5
Boundary Marker +10
Vehicle Touch +10
Course Direction +10
Self Recovery (winching)+3
Assisted Recovery +10
Point Out +80
Did Not Finish point out + 20
Did Not Start point out + 50
General Vehicle Guidelines
Vehicle and accessories must resemble 1:1
Event officials have full discretion to determine if a vehicle is accepted.
No motor on axle or twin vertical plate rigs are allowed.
There are no wheel distinctions. For example, you can run a 1.55, 1.9, 1.7, 2.2 rim in either class. Wheels larger than 2.2 and split diameter short course wheels are not allowed in either class.
Motor, transmission, and electronics must be hidden from view.
Tires should be scale appearing. No comp tires allowed, for example, voodoo pins, HB Rovers, HB Sedonas.
Rigs MUST have a minimum of 6 scale items. (example side mirrors, d ring, winch, sand ladder, driver, steering wheel, hubs, tow rope)
C2+
Tires must be 4.75” or less
Front and rear bumpers are required. Bumpers must be wider that the chassis rails and must extend beyond the body or tube work. Body molded bumpers qualify.
Full rail chassis are required and rails must be 1” longer than the wheelbase
Truggies are allowed, but must replace the ladder frame behind the cab with tube and the truggy rails must extend past the rear axle pumpkin to be legal.
No dig or rear steering allowed
Gates will be a minimum of 12” wide
C3+
Tires must be 5.75” or less
No Bumpers required
Body/tube chassis must be at least as long as the wheelbase of the vehicle.
Full tubers are allowed
Dig or rear steer is allowed, but you can only pick one to run on each course.
Gates will be a minimum of 13”
2.2 Pro and 2.2 Sporty class
Both 2.2pro and sporty will follow the 2018 WRCCA guidelines and rules.
King Of Disney
KOD will be separated into 1.9 and 2.2 classes.
Winners will be determined based on fastest time running the course.
KOD participants will be required to gather a progress marker at each of the progress locations. Failure to gather them all will result in a DNF.
Poker Run
You will run the same course as the KOD.
This course will be ran at your own pace.
You are required to collect a progress marker at each progress location. Failure to gather them all will result in a DNF.
Top Truck Challenge Style Events
Winners will be determined by distance or fastest completed course.
Boundaries will be set on either side of the lane, once a boundary is touched that is the end of your run and your distance is marked at that point.
If your truck rolls over and cannot be recovered without touching it, your run stops and your distance is marked.
Events can include but not limited to: SLED PULL, MUD PIT, HILL CLIMB, TANK TRAP, RUBICON
Participants will be selected by their peers.
Concourse
Winners will be voted by your fellow peers.
Categories for each group will be: BEST OF SHOW, BEST THEME, MOST SCALE, UGLY DUCKLING.
THIS WILL BE A FAMILY ORIENTED FUN EVENT. IF YOU ARE NOT GOING FOR THE PURPOSE OF ENJOYING THE EVENT AND HELPING OTHERS DO THE SAME.... WE REQUEST THAT YOU STAY HOME.
