Rockpiledriver
Check it out guys and gals. Novak just released their new crawler system for the Mini. I have been putting a prototype through it's paces for the past month. This new combo is perfect for the Losi MRC. Smooth as butter low end, and plenty of power on 2s lipo, but can be used with 3s too. "thumbsup"
RELEASE For Immediate Release #3055 Mongoose Crawler Micro Brushless System – 18.5T
NOVAK’S MONGOOSE CONQUERS NEW TERRITORY Irvine, CA – January 12, 2009 – Crawling has taken on a new dimension, and Novak is following its lead by introducing a pint-size counterpart to 1/10-scale crawling. Bred from the Goat Crawler Brushless System (#3019) but sized the same as the Mongoose Micro Systems (#3050 - #3052),
Novak’s Mongoose Crawler Micro Brushless System – 18.5T (#3055) is the first micro sensor-based system specifically designed for 1/18-scale crawler vehicles. The fully-programmable Mongoose Crawler System includes all of the features found in the Goat System, such as instant throttle response, super low-speed drivability and explosive torque, but also includes the ability to run on two or three-cell Li-Po batteries, which the speed control automatically detects through Novak’s auto detect software. Though the micro-sized system packs a lot of power, it fits perfectly in Losi’s® Mini Rock Crawler™, giving users the edge in crawling competitions.
THE MIGHTY MONGOOSE The Mongoose Crawler’s powerful 18.5-turn motor scales over other brushed motors because of its massive start up and low-speed torque. The 380-sized motor features a sensor-based commutation design to ensure no hesitation before acceleration, and provides smooth braking and controlled delivery of power. It provides longer run times than any stock crawler brushed motor and is as powerful as any dual crawler-micro brushed motor setup. Additionally, the brushless motor includes a high-strength sintered rotor with a rugged 1/8” shaft for stronger motor braking power and improved performance in higher temperature conditions. And like all Novak motors, it is completely rebuildable, allowing for the ability to upgrade or replace various motor parts.
LARGE ROCKS, YOU SAY? NO PROBLEM. The Mongoose Crawler offers a plethora of crawling opportunities that are simply unavailable in stock crawler brushed systems. The micro crawler ESC comprises four throttle profiles to fine tune any crawler’s preference.
Linear Crawler — maintains standard motor response in forward/reverse, and features high-powered drag brakes.
Expo Crawler — features the standard crawler profile but uses a built-in exponential curve for smoother response.
Servo/Robotic Mode — features precise and symmetric motor control in forward and reverse for robot applications, but without the drag brake.
Brushed Mode — is automatically selected when used with a brushed motor.
The modifiable programming doesn’t end there. The micro crawler also includes a fully-programmable interface that can be adjusted with Novak’s easy One-Touch™ button and four-colored status LEDs. Moreover, Novak has also built into the ESC a Li-Po Cut-Off Circuitry feature, which prevents the batteries from going below the critical safety voltage level and can be activated in all four throttle profiles. For further crawling opportunities, the built-in motor rotation direction can be modified in any of the three brushless profiles; Zero Reverse Delay is available in all profiles for instant power delivery in both forward and reverse when needed; and adjustable hill/drag brakes are active in profiles one and two, which use battery power to slow the vehicle to a wheel-locking stop.
The Mongoose Crawler ESC has also been outfitted with a rugged 6 volt / 2 amp BEC to provide powerful and precise steering while embarking on unsteady landscape, with no additional BEC to purchase or install.
Novak’s Mongoose Crawler Micro Brushless System – 18.5T (#3055) is scheduled to ship in late January 2009. For more information about this product, visit the Novak Web site (www.teamnovak.com).
MONGOOSE CRAWLER MICRO BRUSHLESS SYSTEM FEATURES
Four user-selectable throttle profiles (3 brushless, 1 brushed) that feature Zero Reverse Delay
Fully programmable interface using Novak’s One-Touch™ button to adjust high-power Hill/Drag Brakes (in brushless crawler profiles), Minimum Drive and Deadband. Drive Frequency is adjustable in Brushed Mode only
Built-in Motor Rotation Reversing (can be activated in brushless modes only)
Sensor-based technology for excellent low-speed drivability
Water-resistant case
Thermal Overload Protection and Novak’s Radio-Priority Circuitry™
Oversized Front Bearing for extra durability and extended life
Aluminum ribbed end bells for additional cooling
Direct-Solder Wiring Tabs for flexible soldering options
Minimal Maintenance
Designed and assembled by Novak in Irvine, Calif., using globally-sourced components
MONGOOSE CRAWLER MICRO BRUSHLESS SYSTEM SPECIFICATIONS
Forward/Reverse ..................... Forward, Hill/Drag Brake, Reverse
Input Voltage ............................ 2-3S Li-Po cells or 4-9 Ni-Cd/Ni-MH cells (1.2V/cell)
On-Resistance ......................... 0.0038 ohms* (brushless per phase); 0.0038 ohms* (brushed)
ESC Footprint .......................... 1.15” x 0.95” (29.0 x 24.3 mm)
Weight (system) ....................... 3.31 oz. (93.70 g)
Rated & Braking Current .......... 40 amps* (brushless per phase); 40 amps* (brushed)
Power Wires ............................. 16-Gauge
BEC ......................................... 6.0 volt/2.0 amp
Motor Limit ............................... 18.5-turn (brushless); 22-turn (brushed mode) [380-size or smaller motor]
Battery/Motor Plug ................... None (battery); 2mm Connectors (motor)
Voltage Cut-Off ........................ 6.25 volts (2S) or 9.38 volts (3S) (when Li-Poly Cutoff Circuitry is enabled)
Number of Turns: ..................... 18.5
Design: ..................................... Sensor-based
Watts ........................................ 82
Kv (unloaded) ........................... 4,400 RPM/Volt
Motor Size: ............................... 380 size: 1.02”D x 1.48”L (26.0D x 37.7L mm)
Shaft Diameter: ........................ 0.125” (3.2 mm) [accepts all existing pinion gears]
Bearing: ................................... Oversized (1/2” x 3/16”) Front; Standard Rear (7mm x 3mm) REPLACEMENT / OPTIONAL PARTS
#5210 - #5212 Mod 0.5 Aluminum Pinion Gear Sets: 11T - 19T (optional) For Losi® Mini Rock Crawler™ use Mod 0.5: 15T
#5304 Input Plug Harness: Mini (optional)
#5509 16G Silicone Brushless Wire Set (replacement)
#5683 Power Trans-Cap Module – Mongoose (optional)
#5720 - #5723 Low-Loss Power Connectors (replacement)
#5915 Three-80 Sintered Rotor (replacement)
#5916 Three-80 Bearing and End Bell Kit (replacement)
*Transistor’s rating at 25 degrees C junction temperature. Mini Rock Crawler™ is a registered trademark of Losi®. One-Touch Set-Up™ and Radio-Priority Circuitry™ are registered trademarks of Novak Electronics, Inc®.
Minimal Maintenance
