i just finished putting my wreckluse together after running in to many problems, and now i go to run it and it has minimal torque..
i have
motor: 55t integy
esc: novak super duty xr
battery:7.2 stick packs
trans:losi comp crawler 13t pinion
axles:rock force (30-1)
so it should be comparable to the losi comp crawler but my axles are 30-1 were as the losi's are 25-1 so it should be geared lower then a comp crawler.As for the pinion i went to a 13T and i believe 12T is the lowest the lcc trans allows.And from what im seeing a lcc with a 55t motor has no problem crawling so is there something wrong with my motor or something ? tho it worked fine in my rock force chassis.any input appreciated Thanks"thumbsup"
i have
motor: 55t integy
