I had been competing in the NMRCC 1.9 and 2.2 Trail Classes with my AX10 build for a couple of years, and after slowly upgrading my AX10 piece by piece (not much AX10 left at this point) I had started thinking about building a second rig with the spare parts so I could have a dedicated 1.9 and 2.2 rigs to compete with. What really got this build kicked off was an all-metal Hot Racing Wraith transmission I got for free off one of the other NMRCC members but ultimately ended up not using. I had a spare XR mod AX10 axle, but after looking at options for another axle to pair with it, I ended up just buying a set of SCX10 Pro portal axles (AXI338001) which wasn't really much more expensive than piecing together a Capra axle, and I figured the width suited a dedicated 1.9 build better. I used the G-Speed V4 chassis I won at the 2023 NMRCC state championship, my old AX10 shocks with Axcess springs, my old aluminum AX10 lower links, my 1.9" Ruptures with Crawler Innovations dual stage foams mounted on AMK competition wheels, my Hobby Wing 1080 ESC, my Team Brood 5 slot 11T motor, and my old Injora/SPT low-profile 35KG servo. I had planned on running an old HPI early Bronco Body I had, but I decided against it since it was so big and bulky and ended up using a Proline Coyote Grande Body since it was competition friendly and clearly resembles a Bronco II (albeit with 4 doors).
I apparently sucked at getting pictures of the build, but I put some Vanquish 33/8T underdrive gears (VPS08331) in the rear along with a "Chilux" OD-3 transmission which has 18% rear underdrive underdrive for a total of 29.8% overdrive to the front. I am running a Robinson Racing 17T pinion (RRP1417) for a 68:1 final drive at the front axle (88.5 at the rear). I am also using the Dlux Fab brass axial portal knuckles along with their super heavy brass portal covers in the front. In the rear I am running the Injora light brass portal covers. I printed a tray that attaches to the axle servo mount to mount my ESC and receiver (FlySky BS-6) to the front axle.
XR10 Mod AX10 rear axle width compared to the SCX10 Pro portal rear.
Chinese Dlux OD-3 knock off. Excellent quality for less than 1/3 the cost of the Dlux unit.
About 100g lighter than the aluminum Hot Racing Wraith transmission that I started the build with.
Stock rear SCX10 Pro portal weight.
Added some Injora light brass portal covers and Vanquish 4.125 underdrive gears.
Weight reassembled.
Stock front SCX10 Pro portal weight.
Front axle weight with the Dlux knuckles and portal covers.
Weight reassembled.
