NMRCC 1.9 Trail Class Build
Chingon
Central
I had been competing in the NMRCC 1.9 and 2.2 Trail Classes with my AX10 build for a couple of years, and after slowly upgrading my AX10 piece by piece (not much AX10 left at this point) I had started thinking about building a second rig with the spare parts so I could have a dedicated 1.9 and 2.2 rigs to compete with. What really got this build kicked off was an all-metal Hot Racing Wraith transmission I got for free off one of the other NMRCC members but ultimately ended up not using. I had a spare XR mod AX10 axle, but after looking at options for another axle to pair with it, I ended up just buying a set of SCX10 Pro portal axles (AXI338001) which wasn't really much more expensive than piecing together a Capra axle, and I figured the width suited a dedicated 1.9 build better. I used the G-Speed V4 chassis I won at the 2023 NMRCC state championship, my old AX10 shocks with Axcess springs, my old aluminum AX10 lower links, my 1.9" Ruptures with Crawler Innovations dual stage foams mounted on AMK competition wheels, my Hobby Wing 1080 ESC, my Team Brood 5 slot 11T motor, and my old Injora/SPT low-profile 35KG servo. I had planned on running an old HPI early Bronco Body I had, but I decided against it since it was so big and bulky and ended up using a Proline Coyote Grande Body since it was competition friendly and clearly resembles a Bronco II (albeit with 4 doors).
I apparently sucked at getting pictures of the build, but I put some Vanquish 33/8T underdrive gears (VPS08331) in the rear along with a "Chilux" OD-3 transmission which has 18% rear underdrive underdrive for a total of 29.8% overdrive to the front. I am running a Robinson Racing 17T pinion (RRP1417) for a 68:1 final drive at the front axle (88.5 at the rear). I am also using the Dlux Fab brass axial portal knuckles along with their super heavy brass portal covers in the front. In the rear I am running the Injora light brass portal covers. I printed a tray that attaches to the axle servo mount to mount my ESC and receiver (FlySky BS-6) to the front axle.
img_8209-jpg.917391
XR10 Mod AX10 rear axle width compared to the SCX10 Pro portal rear.
img_8214-jpg.917393
Chinese Dlux OD-3 knock off. Excellent quality for less than 1/3 the cost of the Dlux unit.
img_8593-jpg.917394
About 100g lighter than the aluminum Hot Racing Wraith transmission that I started the build with.
img_8596-jpg.917395
Stock rear SCX10 Pro portal weight.
img_8599-jpg.917399
Added some Injora light brass portal covers and Vanquish 4.125 underdrive gears.
img_8598-jpg.917397
img_8679-jpg.917407
Weight reassembled.
img_8601-jpg.917401
Stock front SCX10 Pro portal weight.
img_8677-jpg.917405
Front axle weight with the Dlux knuckles and portal covers.
img_8678-jpg.917414
I recycled the Hobbywing 1080 G1 I was previously using in my AX10 build. I went with XT60 connectors for the battery plug as well as the motor plug. Old picture from when I first got it.
img_6879-jpg.602831
The Team Brood 5 slot 11T motor I am running (also recycled from the AX10 build).
img_7239-jpg.679082
I am running the OG AX10 shocks with some Acxess springs I picked out from their catalog (PC032-625-10.000-SST-3.407-CG-N-IN) and some lower spring seats I printed that give slightly more compression travel than the stock spring seats and keep the new springs preloaded and from coming unseated as easily.
Acxess springs compared to the Axial "Red" AX10 springs.
6efb866e-378e-400e-8dfe-1db73c010da1-jpeg.670999
Ignore the Traxxas shocks, those are what replaced the AX10 shocks on the other build.
img_8215-jpg.852809
The AMK competition wheels I bought off Amazon. They have about as much clearance as you can get with a 1.9" wheel and seem like pretty nice quality for the price.
img_8591-jpeg.911643
The foam setup I am running with the 1.9 JConcepts Ruptures. Obviously softs up front and mediums in the rear. I think I would like to try some hard outer tuning rings since I think I am getting too much lug folding, but the lateral stability has been pretty good.
img_7639-jpg.761078
Here's the specs of the "Injora" servo I recycled from my spare parts since I was trying to save a little money when I started the build. It was actually a great, cheap low profile servo performance-wise. I replaced it on my AX10 build because it was getting some bad servo shakes and would act up when it got hot, but it had plenty of power running off the HW 1080 G1 ESC without a BEC and was super fast. In hindsight, I shouldn't have recycled it since it really screwed me at this rigs debut at the 2024 New Mexico State Championship when the servo shakes got so bad, the rig was practically undrivable.
200d66b0-5393-4c09-9595-48987ff17104-jpeg.670998
Ignore the other parts in this picture, here is the Protek 3S 1400 mah batteries I am running in this build.
fullsizeoutput_27-jpeg.692880
Ignore the tires, these are the G Speed V4 carbon rails I am running that I won at the 2023 New Mexico state championship.
img_7651-jpg.761201
I designed and printed my belly skid, boat sides, body mounts, Rear upper links, Rear link riser, and my ESC/Receiver tray that bolts to the stock SCX10 Pro BTA servo mount. I designed the rear body mount as a hinge (inspired by my SCX24) so I only have to pull two pins to lift the body off.
Mocking the body up. I cut a bit off the front of the G Speed frame rails to get them to fit behind the grill.
img_8764-jpg.917431
img_8763-jpg.917429
Painted with some automotive interior paint from Seymour and stickered up. I wanted the paint color to match my real Bronco II, but it ended up being a bit lighter than I was hoping.
img_8770-jpg.917432
All put together and ready to rock.
img_8772-jpg.917434
img_8773-jpg.917435
The wheelbase came out right at 13" which is a bit longer than I was originally planning on, but seems to be working pretty well. Total weight ended up at 5.64Lbs with a 57% forward weight bias, which is a little heavier and a little less forward bias than I was hoping for, but not bad.
img_8774-jpg.917438
img_8776-jpg.917439
It ended up doing well at its debut competition other than the old Injora servo that shook worse than Michael J Fox. I knew I should have bought a new NSDRC RS700V2 direct power servo before the comp, but I didn't want to spend another $125 on what was originally supposed to be a spare parts build. Other than that, I am pretty happy with the way it performed. The drivetrain is excellent and feels pretty peppy despite the gearing with my old Protek 1400mah 3S batteries. It is a bit more top heavy than I was expecting with all the weight in the axles, but I did intentionally build it with some more belly height over my AX10 since that build might be a little too low.
I feel like I performed about as well as I could have in the 1.9 class at the NMRCC state championship with no major mistakes. I ended up in 7th place which I am happy with for an untested build without any seat time before the competition against some great drivers.
img_8790-jpg.917440
img_8789-jpg.917441
img_8794-jpg.917442
I went ahead and picked up an NSDRC RS700 V2 direct power servo from Hittman Fab after the competition. I had to swap my servo horn out since the output is more compact than the SPT servo that I was running before. I just picked up one of the cheapo Amazon special 24mm clamping aluminum units and it works perfectly. I took it out again to experience the truck for the first time without servo shakes and it did great! I enjoy driving it more than my AX10/2.2 build. About the only change I have in mind at this point is converting to an AM32 ESC and compact outrunner motor along with going to 4S to cut 80-100g and get a battery I can mount on the front axle. Hopefully that gets the COG down low enough it is just as stable as my AX10 despite the narrower width and shorter wheelbase. Pulled off some stupid lines I didn't think it would.
Some pictures:
img_8798-jpg.919188
img_8800-jpg.919193
A shitty video I took running this line a second time after it surprised me and made it the first time. It is hard to film and try to drive one handed, and of course the video does it no justice.
NMRCC hosted the Seasoner opener barbecue on February 8th. It was just 1 course for each class they run, but I ended up getting 2nd. No pictures of my rig, but here's a cool shot one of the other members got of my judging.
Nice looking truck and congratz on the second place.
You mentioned underdriving the rear axle and putting in a gear reduction in the transmission and calling it an overdrive in the front. To overdrive the front axle you need to put new gears in it to make it faster. If you only mess with the rear axle and the transmission it is a gear reduction in the trans and an underdrive in the rear and the front stays the front. Have a good day.
NMRCC held their first 2025 Trail class competition on February 23rd which had a great turnout. I started on course 2 and had the 3rd best score, but my day went downhill from there. I had a perfect run going on the third course, but snapped a rear link rod end after taking a hard drop through the second bonus gate. I tried to keep driving the course with the rear axle flopping around, but I couldn't get through gate 5 and chose to end my run and go fix it. I went back after the 1.9 competition was over and was able to run the rest of the course clean after fixing my truck, so that was a disappointing break. On course 1 I was being stupid and made several mistakes and ended up DNFing on gate 10 instead of being smart and just taking a gate.
NMRCC Comp #1 Trailclass Scores
1.9 Trailclass
1. Christian -39, -49, -49 = -137
2. Garret -49, -39, -39 = -127
3. Chris B. -17, -31, -49 = -97
4. Thomas -29, -29, -24 = -82
5. Zak -17, -2, -35 = -54
6. Kevin +22, -15, -34 = -27
7. Phillip +22, -18, -21 = -17
8. Stephen -17, -17, +24 = -10
9. Mike H. -4, -29, +26 = -7
10. Brian -17, -16, +28 = -5
11. Orlando -10, -16, +26 = 0
12. Jose -16, +2, +26 = +12
13. Jesse -7, -7, +26 = +12
14. ME +22, -38, +32 = +16
15. Anthony +11, -16, +30 = +25
16. William +28, -28, +28 = +28
17. Rona +2, +26, +28 = +56
18. Raul +34, +22, +30 = +66
19. Sunshine +22, +26, +36 = +84
20. Rich +28, +26, +36 = +90
No pictures of me running, but a few of me judging. Here are some pictures from the event.
The bonus drop that ended up breaking my rig. The picture doesn't do it any justice.
A picture of the 1.9 rig parked with me getting some practice in with the 2.2 in the background.
It is a Dlux OD-3 clone which is an 18% underdrive to the rear axle which combined with the 4.125 rear gears (3.75 in the front axle) works out to 29.8% overdrive in the front relative to the rear axle.
Underdrive in the rear axle doesn’t work out to overdrive in the front.
It's the same thing. The front axle is spinning 30% faster than the rear. I posted the final drive ratios for both the front and rear, so I am not sure what you're hung up on.
Anyway, here's a few pictures from the last time I had it out at a spot close to the house.
img_9114-jpeg.989824
NMRCC got a new president and VP this season, so they made some rule changes to the trail classes for the first time in a long time. They decided to ban the Ruptures I am running on both rigs which pissed me off a bit, but oh well.
Here are the NMRCC Trail Class Rules for anyone interested:
2025/2026 Trail Class Rules
They do apply for both classes (1.9 and 2.2) unless specified:
Any rule with asterisks is new
Chassis:
- Chassis rail length must be as long as the wheelbase (adding parts to the chassis to make it longer isn't allowed)**
- Chassis can be any regular rail (metal or carbon fiber), stock rail, stock tube, custom tube, and TVP (twin vertical plate).
Vehicle weight/ Added weight:
- Knuckle weights ARE allowed. Weighted wheels are allowed.
Body:
- Bug bodies ARE allowed
- Bodies must be scale in appearance.
- Tube frame chassis must have a minimum of at least a roof, hood, and sidepanels.
- Hardbodies are allowed.
- NO competition style bodies such as Lattice Innovation bodies, or 1/16 and smaller bodies
Tires:
- Scale tires only.
- NO competition or pin tires allowed.
- Tires can be siped, grooved and trimmed.
- Cut and shut tires are allowed, but as for the 1.9 class, only narrowing is allowed (no sidewall modifications)**
--BANNED TIRE LIST--
ALL Pin style tires are not allowed (For example: Reefs RC Cheater tires or Ibex)**
Sedonas
Rovers
Dlux Goats**
JConcepts Ruptures**
Extreme Route Lampreys**
Losi boss claws
Chisels
Panthers (all types)
Wheels:
- Wheels must be either 2.2" or 1.9", no other sizes. They will be ran with the corresponding tire, and ran in the corresponding class.
Electronics:
- One motor limit
- No 4WS or Dig is allowed.
I should have probably bought some 4.75" JConcepts tires, but I like the height of the Ruptures, so I ended up going with the Proline Trepadors and some new foams from Crawler innovations with the ultra dense black foam inners. I bought another set of the same wheels so I could keep my Ruptures ready to go still.
From my experience with the heavy weight inner foams on my 2.2, I learned that it doesn't vent well and if you wad a tire up, it takes it a while to get its shape back. I decided to drill some holes in the inner foam with a #18 drill bit to eliminate that issue.
After assembling the new combo, I am concerned how much harder it is than the Rupture setup. I need to get out and start breaking the new tire in, so I'll find out soon enough.
It’s not the same thing, if you don’t change the front axle then it isn’t overdriven. The front axle is just “driven” the rear is underdriven.
I took it out today with the Trepadors and burned a pack to try and start getting them broken in and get a feel for them. I have some mixed feelings about the new tire and foam setup. The sidewall grip seems to be better, and some things it seemed to do worse and some things seemed to be better. It seemed to be a lot worse on slab climbs than the Rupture setup.
I got straight denied on two climbs, although one might have been because the rear tires were packing with mud since it just snowed yesterday. Another one that I have spent tons of time trying to get in the past, it more or less walked up today.
Anyway a few pictures.
