Ok, this is embarrassing to ask, but I don't know the answer. If I recall my Wraith has an external BEC that drew power straight off the batter wires and then out to the servo bypassing the ESC. Now I am building a Bomber and I got the Mamba X with internal BEC. I'll be using the Savox SA1230SG Monster Torque CORELESS Steel Gear SERVO at 6v.
Here's the green behind the ears part. How do I access the internal BEC power? I am thinking that once I plug the ESC into the Rx the internal BEC powers the servo plug/port and I set the power amount in the Castle link. Is that correct? Could I also use this to power some small lights? Would that just go into one of the other ports on the Rx?
Sorry for the simplicity here. I'm sure this is foundational, but as you can see my foundation is still being built!
WHile we're at it. Exactly what is the Aux wire from the Mamba X for and can you give me an example of how that is intended to be hooked up and used?
