DavidVonDoom
Hey y’all, got a nice new wrangler and with it, a pile of questions. I’ll try to keep this succinct
1, my Jeep leans on the drivers side (I have a shorty 2s on that side to balance). I’ve seen mention that 50-60 weight shock oil in the rear could help this. Is that the case and if so, what should I do in the front?
2, could I get some tire and wheel suggestions (as I understand the portals make the wheel choice difficult)
3, any mods to help it crawl better? I temporarily removed the foam but that seemed way too soft. Also, after I did that 1 wheel wouldn’t vent (3 would squish/whistle and immediately refill with air, 1 wouldn’t refill and would stay flat). Why is that?
4, I’m not sure my dig is working properly. In videos (primarily rc sparks gladiator) you can see he hits his dig on the fly, mine needs to be “reset” after I use it or else it’ll disconnect the rear axle and give me fwd only. So for me, I have to stop, engage dig, make directional adjustment, then fully stop moving, press the dig switch the opposite way to basically cycle it, THEN I can continue traveling. Is there a way to help that?
5, if I have extra lighting kits to add, can I just plug them into the esc wherever there’s an open spot? I can’t recall...
Thanks y’all, happy crawling!
