clockwork
I picked up a CC01 for $120 on ebay with no wheels/tires, or body. It has a lot of upgrade parts on it and came with a bunch more but it looks like it was not run much. The rear wheels wouldnt turn but I thought it just that I didnt have wheels on it and I couldnt get a good grip on the hexes. I pulled the motor and noticed that parts Tamiya calls G2 "gears" (they are plastic bushings) were missing and I found them on the parts tree and installed them. Still no luck the spur gear was bound up I think because of this bump in the housing caused by a screw that was too long being put in on the skid plate. Before I take it out I would like to know if it belongs there (picture 1). The truck came with steel front and center skid plates that were not installed, maybe he tried to put them on and the screw pushed into the housing? The second issue is that with the steering at neutral and the links even, the left hub does not align with the right (picture 2). Is that normally just adjusted out with the steering link? I think he may have just given up on it, the rear axle housing had a few stripped screws and the wrong screws were used in many places on the truck. Finally picture 3, There is very little travel in the front end and I wonder if the upgrade shocks he installed might be too long for the front? Sorry for the long ramble and thanks if you read this far and for any help!
