remedy00311
So i just got the Element RC Senduro and really excited to take it out to some rocks. As i was driving it around the house i noticed that when it goes pretty fast in reverse vs going forward. Is this normal w/ a rock crawler?
also try not to "drive it around the house" much. the overdrive front wheels don't play nice with the rear unless you are on dirt.
I would venture to say Sinchu was somewhat tongue in cheek referring to the potentially unreal grip, when a little slip is needed. I myself avoid too many tight turns on the rec room floor with my SCX. Sticky compound on carpet, with locked diffs -- I can hear the drivetrain straining and complaining.
Even knowing what it does I still set it backwards quite often cause the name is so misleading.I thought the same thing, myself (makes friggin sense), and then I read the so-called manual.
Nah, with a hobbywing 1080 just set the reverse to 50%so if i swapped to a different tx/rx…?
bummer as i actually like the RTR radio gear for the 3rd channel.
ironically i bought a 4 ch. radiolink for a winch setup but discovered none of the channels are 3 position lol woops!
I disagree with this statement.
