One of the 5 new vehicles that Redcat released today is the Camo X4. This is a Yeti & Rock Rey style rock racer with an independent front suspension and solid rear axle.
The vehicle has about a 14" wheelbase, so it's right around the same size as the Yeti and the Rock Rey. It's got a 3300kv 540 sized Leopard motor, which seems a bit small to me. The Rock Rey and Yeti both use a 550 sized motor. The Speed control is a 60a Hobbywing, which also seems a tad small.
The radio is the same 2 channel Flysky that comes with the Gen7.
Overall the chassis looks like a pretty good design. I'm not seeing anything that really jumps out at me as an obvious problem or weak spot on the chassis or the suspension.
The rear axle appears to be 100% identical to the front & rear axles in the new Horizon Hammerjaw, which itself appears to be an updated version of the RGT Rock Hammer. The Rock Hammer is made by HSP, who also makes the Redcat Everest 10 and Gen7, so it's very likely that HSP is also who makes this new Camo X4. This axle design seems to be a much better design than what's used in the Rock Hammer/E10/Gen7, except that I'm really not sure about the longevity of the spool design. It looks like they tried to share as many parts as possible with the front differential, including the dogbone-style drive cups. I would have much preferred to see them stick with the more traditional style driveshafts & spools used in the rear E10/Gen7 axles. With any luck, it'll be easy to swap in an AR60 locker & axles to replace this outdrive & dogbone stuff.
Redcat is showing an MSRP of $389. If the street price ends up below $300, this thing may end up being a huge bargain. I recently bought a Yeti kit, and I bought a Hobby King Desert Fox a while back was a "budget" Rock Racer to compare to the Yeti. I'd love to see if I can get one of these to throw into that comparison too.
