New Product Trail Trekker Wheel Wideners
LavaCapCrawling
Pollock Pines
Hey my name is Zach I am new to micro rock crawling, forums, and vending. I came up with this idea while watching my trekker roll down a hill.
This is the release of new wheel widener/wheel weights that are compatible with the Trail Trekker.
These wideners offset each side three millimeters for a total of six millimeters total. Each spacer and barrel nut add approximately nine grams to each wheel. The barrel nut is flush with rim and should fit under any washer type weights. They are for sure compatible with the stock Losi wheels and Hot Racing Bead Lock alloys. Spacer is brass and the nut is 316L stainless(very corrosion resistant). I make these personally and they are of top notch quality and craftsmanship.
Crawlingwide - YouTube
Wheel Widener w/Spanner Part #K12539B
Price is $34.99 shipped. Spanner bit is included.
Available with 4.5mm hex barrel nuts.
Currently up on eBay
http://www.ebay.com/itm/Losi-Trail-...racter_Radio_Control_Toys&hash=item3a7c5a316b
Thanks,
Zach
Is there any way you could make the outside wheel weights look like something? Babymoons? Or maybe have them fill up the wheel like its actually the wheel? Just curious????
What's the word on the micro crawler spec weights? I have a Trekker, but very shortly it'll have HR one piece lockouts in the rear. The shafts are setup for Micro Crawler hexes. I'm gonna need a set for the Trekker and the Micro Crawler. That'll give me another mixed set for another Trekker buildup!
Might I suggest offering a wheel nut that doesn't take up the inside of the rim. The weight is a plus but I'd like the option of not messing with the look of my scale rims. Or there's the most awesome if you could make the outer weight/nut look like a 5 lug. Not sure if that's possible as its so small.
I have checked you eBay listing and it says you nly ship to the Americas . . . can you ship to the UK (it is only 36g in an envelope ?
