New Bright JK on Scx 10 jeep
Jmoe4
Chambersburg
I have a stock axial scx10 jk. I'm trying to mount the New bright jk on it but I'm having trouble cause the seats are hitting the motor. Has anyone mounted this body on thier jk without cutting, moving motor and moving the axles? I am trying to build this as cheap as possible. Pictures are more then welcome.
You'll have to move the axles to make the body fit correctly. The solution motor and transmission would be the GCM Racing front mounted transmission plate and a Transfercase.
You could also just move the stock transmission to the front of the frame by making a mounting plate. But you would still need a Transfercase of some type.
Just move your axles, Front shock hoops, did mine last month no cutting look 1.9 pic section page 66 close to bottom of page
The axles aren't the problem, just buy a transfer case and move the motor forward to under the hood
Or flip the trans so the spur gear is lined up with the seat backs, it will allow you to lower it a little bit with no cutting
