Need new Cab and bed.
JamesBC
Canada
Question for the ones that know.
Been looking at Hilux Cab to replace my Brusier Cab with, they look the same so my question is, are they the same?
Also would like to know if this bed would fit the Hilux Cab.
I know there will have to be changes on mounting bed and cab to get away from the pin through type but more like to know just how close these will fit.
My Bruiser is the new one if that makes a difference.
Thanks
Jim
The cab will fit. They are the same.
As for the bed, if you are using the original switch cover and steering servo location, that drop bed will stick up. You might have to relocate the switch cover and/or servo box.
Hope this helps.
Post some pics.
Thanks, helps alot. Its hard to tell from a picture and with shipping to Canada just wanted to make kind of sure it will work with some changes here and there.
Steering servo is going to move up front and switch will be easy to move.
Also will have to make up cab mounts so I can use the same holes along the bottom of the cab much like the tamiya semi's use.
In time will, first have to order it, then have it spend a week or two in Canadian customs. Then, should we have mail since they are threatening to go on strike, maybe two weeks after customs is done to get from Vancouver to where I live. After all its 30 miles away from Van.
