Almighty Malach
I have a feeling it's the 8" tires and the spacers between the rod ends and upper link mount. I never had any issues with the link mounts coming loose with just the rod ends bolted up.
it look good, the chassis is not too high?
I like how those axles were built instead of using the delrin tubes option we used to have. may I suggest modifying an axle c or 3d printing caps for where the c hubs used to bolt to on the axle? might be able to be a cheap insurance policy incase those tubes ever decide to twist in the housing. could also make it the full length out to the c hubs if 3d printed.
Thank you. What do you mean by too high?
what foam setup are you running in this rigs shoes? also, how much does the truck weigh in at?
im building a losi worm based rig and would like to think up some foam setups. comp cut inner front soft outer front. regular inner rear soft outer rear? or should I try out med outer rear comp cut inner?
the steering is not to progressive, don't you think?
sometimes it seems that should be more sensitive
grooving takes so much time for 2.2's lol. I bet it took you a few hours on those 8 inch tires.
how much caster does the rear knuckles have?
8 oz. Not bad. I think my wheel/tire combo will end up weighing more than yours. Maybe not.
I notice a shock setup change. Just the springs?
