Sarra
I've been having a long time problem with data corruption. Specifically, one of my SATA cables is not making a strong connection with the drive it's plugged into. I figured this out when I first installed an OS on this machine, and after install, I got a 'boot disc not found' error. Jiggling the cables fixed the error on reset, and on and off since then, I've had to go in and fiddle with my cables.
Tonight, I had a big problem with data corruption come up. Apparently, when Windows was updating itself last night, the SATA cable going to my OS drive wasn't making full contact, so I've got data issues all over Windows. This came to a head today when I rebooted my machine and I had no drivers, and Windows, even though it was running, didn't want to acknowledge that I have a video card, even though it was actually using said card.
So, I'm moving all of my data over to one of my 1TB drives, backing up my game saves that don't automatically backup to the cloud, and am preparing to remove all of my drives (I have a lot of drives, actually. Three 1TB, 500GB, 3SSD, and a 320 gb laptop drive) and start again from scratch. I'm going to clean off my 500 GB drive and format it, and use it as my boot and OS drive, and my SSD's will get plugged into my onboard SATA ports (I have two PCIE 1x controller cards for 4 extra ports), and the 1TB drives will get plugged into the ports in the controller cards. When I had installed, I meant to put OS and Boot on a single 1TB drive, but I jumped the gun and instead I have a boot drive on a 1TB drive, and my OS is on a partition on a second 1TB drive, meaning having one 1TB drive fail out of the two would screw my system, or cause data corruption when a cable failed.
I'm just glad my machine is running well enough right now to get my data moved and that 500 GB drive cleaned off. Maybe I should invest in some new SATA cables.
Only issue I foresee here is the OS. I have Win 10, and while I like it, I don't have a Win 10 install disc. I got a free upgrade from 8.1, which I legally have a copy of. I'm fine with Win 8.1, but is there a way to let Microsoft know that this copy of Win 10 is about to cease to exist, so I don't have activation issues on my new install?
