I Been a fan of crawling for many years and i always seem to gravitate towards micros i did a build a few years back with a. R7r eclipse chassis bent links a few upgrade parts and wound up selling it and still regret doing it. that was before the trekker came out so the only option was the micro crawler parts and rims were hard to find (their even harder now) and you had to get on a waiting lists to get a hand wound motor the miclaws were always out of stock :lmao: well since then i never losts the interest in micros especially crawlers i wanted to do a new build and i recently found out they were discontinued so i ran out to my lhs and grabbed their last trail trekker the guy even said their not getting anymore in. No matter how old i get rc keeps me out of trouble.. And is relaxing to my mind since purchasing the trekker i been picking up all types of spare parts a dozen packs of mini t steering end cups trekker ball studs drivelines numerous spare parts 2mm anodized. Wheel and trans slipper nuts And today a bunch of 2/56 threaded rod and 1/8th hollow aluminum tube. Today my first parts order came in and i picked up 4 HR aluminum servo mounts to get my 4ws started i should be recieving my DDT 90T AND 100T motors with 10t pinions attached this will be a long a tedious build as my personality always isnt content and i constanly tinker and try to find the purfect setup thinks the same problem over and over in my mind until a solution is reached
Future mods include:
Hr aluminum gear
Hr aluminum gear case
Hr aluminum skid plate
Hr aluminum slipper
Aluminum nut on slipper
Hr aluminum gear cover (MAYBE!)
Carbon fiber fishing drag washer to replace slipper clutch clear plastic one.
Hr Aluminum steering links front and back
Rc4wd beadlocks
Brass wheel widener weights
Mini t links
Bent lower links (Bent at the cup not in center of link)
Miclaw tires if i ever can finds them..
Rc4wd dirt grabber 1.0 tires on a comp rig give a diffrent look (dont think they will grab well)
Crawler x tmc topless chassis
Two hitec hs65mg servos or savox sh-0257mg
Aluminum servo arms
Micro motor fan
Home made shocks. (hr ones are like finding noahs ark)
Here is a few pictures of my truck so far and also my spare parts i will post pictures as i progress thru the build and each mod/upgrade i do Thanks."thumbsup"[/URL
[URL=http://s1110.photobucket.com/user/fatboy109/media/Mobile%20Uploads/1458807073536.jpg.html]
A Few spare parts to start
Hr aluminum gear
Hr aluminum slipper
Rc4wd beadlocks
Mini t links
Aluminum servo arms
Micro motor fan
