MikeTheDiabetic
So ive been wanting a scaler for a while now, every since i got into crawling, but i wasnt going to put out $350+ for another RC. So i decided to build my own as cheap as possible. So far its coming out pretty good and i will document the whole thing here. First i needed a donor car for most of the mechanical bits. Since i have an Everest 10 and love it, I figured i would stay in the redact family since i think you really cant beat the quality for the price. I quickly found that the Everest 10 axles were going to be way to wide for my application so i started looking at the Everest 16 and I found that i could make it work. So the hunt began, and i scooped up a "used" Everest 16 on Ebay for $65. I say "used" because its basically brand new. Not a scratch on it, came with remote and original box. Here is is below:
Then i started stripping down the Everest 16 to see how things were going to layout. I needed everything besides the body and chassis.
Next was starting to populate my new frame. This is the one i bought.
For 1:10 Axial SCX10 RC4WD D90 JK Model Metal Car Defender Frame Set Black New | eBay
For $31 i figured i couldnt go wrong. The quality is actually great and its very sturdy. I also picked up some wheel spacers to fit the width of the body better.
HD 17mm Aluminum Wheel Hub Spacer Fit RC4WD Kyosho Tamiya RC 1/10 12mm hex | eBay
Here they are before i started messing with them.
Finally i started populating the new chassis with the Everest 16 parts. To my surprise, it all pretty much bolted right up. I had to drill 2 holes in the chassis to mount the arms where i wanted them, but thats it. It articulates really well and the only rubbing is with the front wheels on the frame when its at full compression and fully steering lock. Its not even that bad tho.
That last image isn't even at full flex either, Seems to be shaping up the be decent scale crawler. Anyway, since that went together well, it was time to move onto the body. I landed on this body:
Topselling D90 Hard Plastic Car Shell Body DIY Kit for 1:10 D90 Rock Crawler LS | eBay
Again, for the money i couldnt resist. Its a hard body with full interior, widnows, bumpers, everything. It also had a shorter wheelbase than most 10th scale bodies which would help. Also without even really putting 2 and 2 together, turns out this body is basically made to work with this frame. Bonus! So i literally had to do ZERO modifications to make it fit. You can see it really coming together below.
Again, these pics arent even at full articulation. I just tested it and if i pick up the front wheel and flex it, it will raise 5.5" to the bottom of the tire before any of the other 3 wheels leave the ground. All of the wheels tuck really nicely in the fenders and dont rub anywhere. So thats where i am at so far. I am using un-modified, bone stock Everest 16 axles, wheels and tires, links, and shocks to get it into this roller thus far.
Total Cost So Far?
Body - $32.15
Chassis - $29.92
Everest16 - $64.99
Wheel Spacers - $25.00
Total = $152.06
Thats with a remote and everything, i am using my own battery, so im not going to factor that in there. Next will be getting the rest of the driveline mounted. The motor and trans, as well as the steering servo. Not sure which drive shafts im gonna use yet, but i will keep you updated. What do you guys think so far?
Total Cost So Far?
Body - $32.15
Chassis - $29.92
Everest16 - $64.99
Total = $152.06
