I bought a Capra kit a few weeks ago, and before i had driven it I ordered a new cage set off eBay for my second Capra. After driving this one a couple times, the first Capra went up for sale. [mention]Fricker08 [/mention]scooped it up, and hopefully will post his own thread on it.
One thing I want to mention, everything on this build besides the skid plate and motor/Esc I bought second hand, or at a discount. it’s a fairly high end build, but maybe not as expensive as you might think if you’re bargain shopping.
-Stock Capra cage and body set
-UCFab flat 3 gear delrin skid plate
-Incision Capra upper and lower links
-Incision rod ends at the axles
-Stock Capra rod ends at the skid plate (swapped the stock angled rod ends to the upper links as well due to incision front upper links being shorter)
-Trx4 shocks with Trx4 yellow springs, 60wt, white x ring spacers, black pistons and Ti shafts
-Vanquish 3 gear trans
-Incision driveshafts
-vanquish 10.2 Currie f9 axles (u/d ring and pinion in the rear axle)
-Vanquish Currie servo on axle mount
-Vanquish Method Roost wheels with .350” hubs
-Pitbull growlers with 2 stage foam
-Holmes SHV800 servo w/vp 20mm horn
-Castle Mamba Micro x
-Holmes Puller Pro stubby 2700kv
Hope you like it. This thing has become my do it all rig, it’s fast enough to have fun driving on flat ground, it’s possibly my most capable rigs in the rocks, and it just looks damn good IMO. I know there’s a been a few done already, but I’m surprised there aren’t more.
