MST Cush Drive(Slipper), perfect fit on Wheely King!!!
MAGNUMB
DA U.P.
The MST cush drive is a perfect fit with no modification. This should prevent stripping gears all while not having to deal adjusting a slipper clutch. The stock spur cover can also be used.
A small spacer or a few spacers are needed for the screw the secures slipper assm to input shaft. You may also want to use 17t pinion to get back to stock ratio and to due this you'll need to elongate the motor adjustment slot.
Still around? Any update on the perfermance?
Sent from my SM-G965U using Tapatalk
