Motoworx racing 1.9 channel locks
motoworx
Canon City
New November of 2019 the 1.9 8 spoke slant face channel lock 12mm Hex wheel.
Whats New:
This 1.9 wheel is designed to accept Motoworx Racing 12mm 8 hole-2mm detachable hex hub which are included with the wheel
Backspacing is adjustable with the 12mm 8 hole hex extenders in .200" increments.
Motoworx Racing .200″ HEX HUB EXTENDER (8 hole bolt pattern) |
2mm hardware is used on the beadlock rings and for the hex hub mounts. (included)
The outer ring screw hole pattern on the 1.9 MXR* wheel*has a 18 hole or 6*hole mounting option. This allows*for the use of an 6 hole outer ring in comp situations for quick tire changes or a 18 hole outer ring*for scale effect.**1.9 bead lock rings | Product categories |
Weight reducing channel is cut into the outer diameter for weight savings without structural compromise
Compatible with Motoworx Racing center caps.*Motoworx HD\LE Center Cap |
Sold Individually. Be sure to add the desired quantity to your cart.
