Greetings guys,
I have finally finished my SCX10 II Rubicon Hard Body project, all except motor, since I had YR 540 rebuildable 35T motor removed from another vehicle. Problem is next: motor gets extreemely hot after 10 minutes of running on 13T/56T pinion spur, I have run it with stock Axial ESC which got burned on the first run, then I installed ESC from my Summit EVX2, which stays completely cool and supplying enough power, that's why my diagnoze is underpowered motor.
There is no binding anywhere, since rig rolls easily on the downhill even in 1st gear without drag brake and all wheels are turning freely on turned of vehicle.
Total weight is 7kg with battery and scale details, even in 1st gear on 2s motor struggles and stucks from overheating on steep crawling uphills.
Thinking about going brushless, but no manufacturer provides recommended details on max permitted load on the motor.
I could put 4274 sensored HW combo, but Axial gearbox does not let doing that, that's why I have to go 540-550 diameter brushless motor.
What would you suggest? Buying 90$ brood or Holmes handwound motor is good, but I would like to add couple bucks and get brushless for efficiency and better control.
What do you advice to get from these options or add some more?
I prefer quality with some nice additions like bluetooth connectivity on the Go etc. and low noise within ~200$ budget
1. Axe FOC 1800KV-2300KV (Cant really get information regarding max permitted weight or pulling load)
2. Mamba?
3. Mamba with 1415 motor which is rare?
4. Holmes? (Don't know much about them)
5. Some Chineese sensored combo to beat sh*t out of it (If anyone got good experience with them)
pics for understanding the weight with CI Firm dual stage foams
Thanks in advance for help!
2. Mamba?
