motor esc caibration
I don't know if you can do this with the Vaterra, but with a Wraith, you can install the ring and pinion two different ways in the diffs. One way the wheels will go forward when pulling the trigger on your radio. The opposite installation of the ring and pinion will make the wheels go in reverse when pulling the trigger.
Can you reverse the ring and pinion in your truck's diffs?
I just looked thru the manual for the Vaterra and it looks like you can flip the ring gear assembly in each axle. Doing that will make the axles run in reverse to what they do now. Then you don't need to change anything on the ESC or radio.
Nope can't reverse them :-( I've removed the sensor wire & reversed a&c its running in the right direction now but cogs a bit when crawling. Don't know what else to do, I think I'll ask for my money back
