More Dig Questions but with research...
monkeyracer
Golden
What is a dig or disconnect?
A dig is a device attached somewhere in the driveline that disconnects power to either the rear, front or both axles to allow a special type of manuever that gives the truck a tighter turn radius.
There are typically 3 modes in the dig's operation; 4WD, Locked, and Freewheel. When in 4WD, all 4 wheels turn just as they do without a dig, shifted into Freewheel, this disconnects the dig axle (typically the rear) and allows it to spin freely from the other axle, shift into Locked, and the dig axle is held in place as if a brake were applied to it.
Usually a seperate servo and a 3 channel radio are required to be able to shift the dig between the 3 positions (if your radio is only equipped with a 2 position 3rd channel, like the Traxxas TQ3, you may lose one of the 3 positions, usually freewheel. There are some threads in the "Electronics" section that show how to obtain 3 positions on the 3rd channel, so it's worth a look in that section to find out how.)
Ok, so when do I use one?
Recently, more and more competitions have "dig lines" or lines that would be almost impossible to complete without a dig, usually tight turns or awkwardly positioned gates.
Shifting the dig into locked rear is similar to applying the parking brake in a 1:1 vehicle. When throttle is applied, the front tires tend to slip and if there is any turn angle on the front wheels, the vehicle will pivot in that direction, allow the crawler to rotate without needing a long distance.
If you've ever been to a comp, the guys that usually do well, have digs, watch how their trucks behave, and you'll start to learn when to use dig to prevent having to take a reverse penalty to line the truck back up.
Another situation where a dig is usefull is a steep incline like a tall curb, for example. The dig can be used to help climb a near verticle obstacle, by using front drive only (freewheel) to help pull the rig over the rock (where if the rear wheels were driving, it would flip the rig over.)
What else should I know about digs?
Well, there's a whole forum at your disposal, so use the search button at the top of this page. One thing I recommend is:
Get (or mod) a radio system that has end point adjustments for the 3rd channel. This helps save the servo from burning out. Some people use a servo strecher to do the same thing.
You want the servo to positively shift the dig into the correct position, but not hum after it's shifted. The humming is the servo trying to pull the shifter further and causes stress on the servo board and motor. It takes a little time to get the end points adjusted correctly, but well worth it in the end. Some companies have a walkthrough on how to set the end points for their dig.
Another thing to add, the location of the servo can also affect the performance of the dig and the truck itself. Mounting the servo to the chassis may allow it to be mounted lower, but when the chassis flexes it may inadvertantly shift the dig into a different position. Mounting the servo on top of the transmission is a good way to prevent chassis flex deflection, but may raise your center of gravity.
A good balance is the new DNA servo mount, the Eritex servo mount, and the type of mount the 3Racing unit uses. These all allow the servo to mount low, to keep COG low, while maintaining a stiff, strong mount to prevent flex deflection. Beware that a weak transmission mount that flexes is just as bad as a chassis mounted servo mount, so make sure the material used is strong enough, and the screws are tightened correctly.
Now, since a dig is pretty much mandatory at comps now. I am looking into getting one finally, but want to make the best decision on which one to get. Here's what research I've done, but if I am missing something, please let me know.
There are basically these options for dig:
DNA/VF (DNA300HD)
Eritex (HRD 3.1)
Vanquish Products (Waiting to be finalized)
Hot Racing (SCP39L01)
CKRC FT (CK1006)
3Racing (AX10-29)
Montrucks Dual Dig (MT Dual Dig)
RC4WD R2 with Dig (X-0361 open, X-0493 enclosed)
Stage 3 Racing (Link not provided, lockergate and dig.gate scandals)
Make My Own (My Link)
Make Your Own Driveshaft dig (Sticky Here)
Here's what I found from searches on pro's and con's:
DNA/VF (DNA300HD)
Pros:
Well thought out design
Nice machined parts
Fully enclosed
Color options
4 points of engagement
New steel internals
Now comes with servo mount
DNA customer service
Replaces the stock outdrive with a stronger piece
Servo mounts to transmission rather than chassis
Cons:
A little on the higher priced side
Needs a torquier servo to keep it engaged
A little on the large side
May have to trim the case if you have triangulated lower links
Drive shaft moves with dig position
Eritex (HRD 3.1)
Pros:
Small size
Hex/Collar style = low torque engagements
Almost Fully Enclosed
Nice machined parts
6 points of engagement
Very well thought out design
Eritex customer service
Drive shaft does not move with dig position
Cons:
The most expensive MSRP out of the ones I've listed
Servo mount is extra money (or just make your own)
Out of stock right now (Gerame is working on them though)
High torque servos may cause binding issues
May need a "Dig Condom" to protect from dust and dirt entering the top of the unit.
Pros:
Low price
Steel internals
Once end points are dialed in, parts polished, and output beveled works great
Fully enclosed
Cons:
HR's questionable design-jacking - seems to be a copy of one of the other digs here (not the only thing they've copied)
Servo mount designed for stock chassis
Needs a little massaging to get it to work well (polish and beveling)
Only 2 points of engagement - may need a "reverse bump" to disengage
Hot Racing (lack of) customer service
CKRC FT (CK1006)
Pros:
Small size
Spur side mounted (keeps motor weight forward)
Low price
Can be added to any other dig to have dual dig
Cons:
Optional servo mount is extra
Open to dust and dirt to clog the dogs
Not seeing a lot of positive threads here on this dig
Needs the upgrade outdrive = more money
3Racing (AX10-29)
Pros:
Small Size
Includes short aluminum drive shaft and transmission mounted servo mount
Decent price, about mid-range
Cons:
Not a lot of positive threads here about this dig
Takes quite a bit more work to get it working
Unsure on # of points of engagement
Need to get the front drive shaft to match or have mismatched shafts
3Racing (overseas) customer service
Pros:
Dual dig design
Can use one side or the other alone if needed
Cons:
Very close design to some of the other digs
Higher price
New, not a lot of reviews on this dig
Needs 4ch to get both digs working
Make your own servo mount
Pros:
Good price for a trans/dig combo
Fully Enclosed (X-0493)
Nice machined parts
Low profile transmission
Cons:
Needs a new skid plate to mount to
Not a lot of spur/pinion combos for the motor
Open design allows dust and dirt in (X-0361)
Pros:
5 points of engagement
Nice machine work
Servo mount included
Replaces the back of the stock transmission case (front case is optional)
Removeable rear plate for easy access to internals
Cons:
Blatant copy of the DNA dig (didn't ask permission to improve it)
Questionable business practices (Mass PM scandal)
S3R - Banned from this forum -nuff said
Basically it's a great unit, but a bad company
Pros:
Inexpensive
Experience of building it myself
12 points of engagement
Drive shaft doesn't move with dig position
Cons:
No machine shop to get precision
Lack of precision causing binds
No replacement parts available, I'd have to start over if something breaks
Pros:
Very inexpensive
Experience of building it yourself
Cons:
Bulky on the driveshaft, may cause clearance issues
May lose one of the three positions depending on how you make it
Snap a driveshaft and you'll have to start over basically
The DNA and Eritex look to be the best, the Vanquish has potential as well. These 3 companies have spent the time to develop their units, and all 3 have excellent customer support. The rest of the digs all have a suspiciously similar design. The RC4WD version replaces the stock Axial transmission. All digs take a little time to set them up and dial in the end points, some take less than others. Pricing on the above list ranges from $40ish to over $100. I wanted to know what was the best bang for the buck that I wouldn't have to mess with every comp. However, I've seen plenty of positive reviews on some of the lower priced digs that with the price, are tempting to get. I want everyone's opinion though.
If I am missing a pro or a con, please let me know. Also, please leave the S3R bashing out of this thread, they're banned, I don't want to be as well.
Basically, post what dig you have personal experience with, and what you think are the pros and cons of the dig. If you have modded it to work well, please post that as well. Also, post what servos you've used, and what works well and what doesn't. The price of the dig servo should be accounted for when shopping for a dig.
The price on the HRD 3.1 website is retail. With the right coupon, the dig and servo mount goes for about $90.00.
Also, HRD 3.1 IS NOT fully enclosed.
It is east enough to put a dust cover on it I just don't want people mislead.
Look at post 118...
http://www.rccrawler.com/forum/showthread.php?t=177788&highlight=dig+condom&page=6
I have seen and played with almost every dig on your list and will say, each design has its ups and downs. If you would like anymore info about the HRD 3.1, please feel free to email me.
Gerame
Good list and descriptions. The Vanquish looks to be promising. It might have internals somewhat like the Eritex, with the lever system it uses, it must use some kind of collar engagement for actuation. I have the Eritex, and have put 4mm set screws in the Eritex' tranny output hex, I just couldn't keep it tight enough, even with red locktite(blame the puller motor for that) I do wish the hex on the rear plate was slightly thicker, I have experienced a few times where it pulled out of lock(again blame the puller) With all the different chassis out now, servo mounts for most of the digs should be fabricated anyway, to get them "just right". The DNA has the most history, and with the steel internals, is now very strong, and still seems to be the "go to" dig.
Look at post 118...
Gerame
Yours is the one I am leaning towards, when will they be back in stock?
And does the coupon with the same name as a video game still work or are there other coupons I should know about?
Digdug is done. I am finishing up the next batch right now and can PM or email you when they are ready.
I will let people know what code to use to get the discount when they are back in stock.
Thanks,
Gerame
Thanks,
Gerame
I'd love a PM when they are ready.
So, I should just wait, save my pennies and get the Eritex dig?
S3R is based right here in Michigan, and the guys that live here won't use there products. Me and 3 other club members where testers for S3R and after everything with Bonus line and DNA, they where dropped like a hot potato.
Ok Ok, we all know the history, let's keep ALL the bashing out of the thread, as monkeyracer said. This can be an informative thread.
I looked at the S3R unit before I found out about the scandal with DNA and Bonus Line.
The unit itself seems to be a good unit, but once I found out that they 'borrowed' a DNA dig, in order to 'improve' upon it, and the fact they stole the design for the bonus line lockers, I decided I wouldn't pay my hard earned money to a company like that.
It's actually a shame, because 5 points of engagement vs 4, and the removeable rear cover are in my opinion a better design. If only they went through the proper process to get it done.
Any one have info on the VP dig that's upcoming so I can add it to the first thread?
One thing I want this thread to accomplish is to gather all the information on all the available digs in one place so me (and other dig-less crawlers) can make an informed decision. Bashing S3R isn't helping to accomplish that.
I want to know about your personal experience with a dig you actually have installed in your truck and use and abuse.
Thanks for the good info so far, keep it coming!
I think the Eritex is a great unit. It's tiny, light, and works well. The puller motor has put alot of stress on it, but it is holding up just fine. Other than the set screw issue I mentioned before(which is not Eritex' fault) I would definately recommend the unit. It shifts just fine, no real hangups at all.
Thanks for the info, it helps!
I understand that as soon as Gerame found out about the set screw issue, he sent new parts out to everyone that might have had a bad one, without any hesitation. That's great service in my opinion.
What about the cheaper digs, are they just that; cheap? Will I regret saving a few bucks to get one? Any other digs I am forgetting (other than the VP dig?)
That, he did! I was one of the first who ordered the Eritex Dig and my set screw did not have a problem, however, before the end of the week, I had a new back plate!
Customer service is a big deal to me and Eritex has NEVER let me down..."thumbsup"
if you are looking to spend little money, this dighttp://www.rccrawler.com/forum/showthread.php?t=101507 will work just as good for about 5-10$. +Servo
But if you are up to spending the money, go for it.
See last post (152) in that thread... and:
Pros:
Inexpensive
Cons:
lack of precision causing binds
Vanquish dig is nearing completion. We should have some with us for the axial west at donner this weekend.
Gunnar you heading up there?
