Short answer......
No.
Sportsman is club-level, Shafty is Nationals level.
Shafty.
Bored? Long answer is as follows.....
I have mine tightened down so as to be largely ineffective. I also run a Brood motor and somewhat low 14/87 gearing. Yeah, if them tires ever get into a bind, and I'm stupid enough to keep the throttle nailed, I'm quite certain broken parts will be my reward. (already have a stock drive shaft that got 'candy-caned' pretty good) But, I'm comfortable taking the gamble, so IMO, no.
Question really is, can you handle the consequences of replacing failed parts, or do you need a stress relief point in there to protect you from yourself?
If I read correctly,
HERE it states that Sportsman was to be a club level class and is apparently not in place at National level events. I went and read through the 2011, 2012, & 2013 Rules, and it looks a lot to me like 2.2 Shafty was crafted as a sort of Sportsman clone to bring the Sportsman rules (local, club level) to the Nationals arena.
Basically in a nutshell, 2011 had the Sportsman class which used the same body dimensions as the regular 2.2 class (allowing bodiless).
2012 saw the introduction of the S class (for National events) in addition to Sportsman (for local club level events), however in the S class bodiless was banned, Sportsman still followed 2.2 class (allowing bodiless).
2013 sees the Sportsman class eliminated, and the S class renamed 2.2 Shafty, again with bodiless outlawed.
The commonality between Sportsman, S, and Shafty has been the focus on keeping digs and rear steering out by specifically noting the use of only two channels on your radio, and (in 2013) spelling out "-2.5.7- Vehicles are limited to 1 ESC, 1 motor, and 1 servo only".
Looks to me like dig, and bodiless are still options, but installing either of these bumps you into the "2.3-Class 2-Class 2.2" and you simply run with the MOA crowd. Looks like 4ws is a no-go for all 2.2 sized classes (Shafty or MOA).
Depends largely on where you plan on running. If you're just running with a local club, you kinda really need to go down there and see what rules they use.
If it helps any, build your truck to Shafty guidelines, and you should still be able to run with your local club even if they're using Sportsman rules.
If you build to Sportsman guidelines (which allows bodiless/but not dig), then if you ever attend a Nationals event you won't fit in the Shafty class, you'll be bumped to running with the MOA rigs. (if you really don't want to get bumped at a National event, solidly mount any legal body over your bodiless chassis, and boom, your Sportsman has now been brought back into Shafty guidelines) (if you insist on running dig, you're running with the MOA's regardless of body/bodiless)
Unless someone else has a different perspective.........
