zidaro
sounds cool, doesnt it!!
my name is not Thor btw
the Norse symbol.
Mjollnir, in Norse Lore, is Thor's (the God of Thunder) Hammer. It always hit its target and always came back, never broken. It symbolizes Lightening. Mjollnir, as a word, means Crusher.
Wishful thinking on a Twin hammer, but thought id give it a name and this one fits for me.
All you get right now is poser shots. Could not leave well enough alone!
Its undergoing a full electronics swap:
Futaba 4pl
Waterproofed Futaba R2104 receiver
Hitec WP Mini shift Servo HS-5086WP 50oz torque
with the Vaterra tranny shift linkage kit to hook it up (24spline) Transmission Shift Linkage Set: Twin Hammers (VTR232007): Vaterra
HiTec Steer Servo HS-5955TG 333oz/0.15sec plasti-dip sealed
CC 10AMP BEC at 6V
Tekin Pro4 3300kv waterproofed by Holmes Hobbies
CC Mamba MaxPro also waterproofed by Holmes
Rob. Racing 18T hardened 5mm Pinion
Losi 51T 32P Kevlar Spur
Carterfab Ultra4 roof V1
Spare mount lowered for better looks and more forward, lower weight
G-made XD shocks- so far
Front- 93mm 25wt. oil 3-hole damper
Rear- 103mm 25wt. oil 3-hole damper
Rear Blue monkey stage 2 suspension upgrade, Links 1 inch longer 2 shock.. $70
RC4wd punisher ii shaft 150-192 mm fits the TH with longer arms.. 5mm bore. This did require a mild amount of dremel work to extend the flattened portion of trans. output shaft to accept the set screw. Easy.
Have Trenton of MG200 building me a front upright shock tower with removable crossbrace to allow me to flip the hood up giving access to battery up front. Trentons shots of finished product tested and enroute. Cant wait to get that bolted up and test out upright shocks and battery upfront.
MG200Designs
HR 12 Alum. Hubs with lockscrew
500K front diff. fluid
**** 4mm turnbuckle upgrade. way beefier and easy install
Pitbulls mounted on Mayhems coming soon, and maybe some better color.
Running on 4200mah 2s Turnigy packs. 3s is in the future once i determine what size will fit up front.
I'm sure as i Hammer down on this thing i will have many improvements to make. I forsee steering issues already and am thinking about that soln.
This is actually supposed to be my daughters rig, so she doesnt bash on my Wraith and new Exo so much, but i seem to be a bit addicted to it. Very Fun.
Shes 8.
Flame Away!!!
I'll update as i make progress and beat it up!
Futaba 4pl
CC 10AMP BEC at 6V
MG200Designs
Shes 8.
Flame Away!!!
