redneckracerx
I don't post too often and usually hang out in the CC-01 forum. I've never made a "build" post either so there's a lot of firsts here. I got a mf (jimney) because my cc was just getting tired from running it almost on a weekly basis. I built it completely stock, open diffs and all, and ran it. It wasn't great but it also wasn't a complete let down. It's a fun little rig!
So I wont bore anyone with the details because its a basic M-chassis Tamiya. Specs are pretty plain jane. It came with a "torque tuned" 540 can and a TBLE-02S esc. I put in a hitec hs5645 for steering duty.
After the first run I realized the tires were too small and on went a set of rc4wd mtz's. I also locked the diffs and installed a set of fast eddy bearings.
photo credit to Jay Rivers
Its funny, you never realize how many photos you DIDN'T take until you want to document something!
This is where I ran into a problem and started looking on RCC. After the trail run with the mtz's I had motor heat issues. Obviously because the tires are bigger. So gear down! Well just like the CC-01 you can only go down to a 16 and that's what's in it. I then discovered this thread and thought MORE MOTOR!
http://www.rccrawler.com/forum/1-5-scale-rigs/548163-daniels-needs-home-500kv-roc-412-suzuki-jimney-goes-recon-g6.html
In case you haven't noticed, I can't do anything normal. Daniels setup is the roc412. Hardly "normal" but I figured why not go crazy! Then this showed up in my mailbox.
Thanks JohnRobHolmes
So after installing it and setting up the ESC for brushless, which was overly complicated for a stock ESC, I took it out for a spin. Man is this thing buttery smooth! And fast! There's more control with this setup than I have ever had before in any of my rigs.
Unfortunately it's faster than I expected...
