TrickyRicky
In the TRX forum a user is asking a question that I would like to know the answer to also. Using a Mamba X ESC in a TRX4 can you use the AUX wire to trigger crawler mode (drag brake and instant reverse) using the channel for low range? So when in high range its normal brake and reverse but when switched to low range it goes into crawl mode. Thanks!
