Hello everyone,
I'm looking for some help with a new power system on my TRX-4.
I recently installed a Castle Creations Mamba X with a 1900kv 1406 motor and I noticed that the drag brake is a bit weak on its maximum setting. The truck rolls slowly on a 45 incline.
The batteries I'm using are 3S 4000 mAh. I calibrated the esc correctly, maximised drag brake, maximised brake, maximised reverse throttle and even set up the aux wire on a separate channel to be able to customise the drag brake on the fly.
This is my first dip in the crawler territory and maybe this is normal, but I think the stock power system was holding a bit better.
Should I use 4S batteries? Or am I missing something?
Thanks
Thanks
