mamba micro pro calibrating issue
choco204
canada
Hey guys i have built an xr10 and i received my escs the other day and cannot seem to get them calibrated. i hook up all my electronics and get steering responce but havent seen my motorz so much as make a glitch so far. i have them both programed with castle link. my 4pl is all set up as far as i know. when i try to calibrate i pull trigger plug batt into ecs and it starts to blink yellow led. it wont detect full throttle or brake or neutral. motors dont do anything. im stumped any advise would be greatly appreciated. all my trims r set to 0 and i rev throttle channle already.
yea iv check all of the above. it is still doing same thing. i bought a new batt and still same thing. the escs seem to be counting cells and then going straight into low voltage cutoff cause i get green and yellow leds blinking. im completly lost now. thx for trying to help me out guys.
Yeah I've checked all of the above. It is still doing same thing. I bought a new batt and still same thing. The ESC's seem to be counting cells and then going straight into low voltage cutoff because I get green and yellow LEDs blinking. I'm completely lost now. thx for trying to help me out guys.
According to the "troubleshooting" in the linked document, green & yellow blinking is "LVC". You can change the setting using your radio if you don't have a Castle Link.
We're not giving up yet....."thumbsup""thumbsup"8)
Yep, what they said"thumbsup", I had the same issue with one of my micros with the latest firmware , so I programmed the esc to the receiver with the Lvc turned off , it programmed fine, then I went to the castle link and turned the Lvc back on and it worked perfectly.
I know we have been emailing on this. What firmware are you using? I ONLY use V 1.24. You can roll back to that by selecting it and then updating. From there use the auto detect @ 3v per cell, forward to brake to reverse, drag brake at 213%, full reverse throttle and brake power, and brushed reversing.
Also, read through this, its a thread I started a while back to help folks. The first post has a screen shot of the settings I use
http://www.rccrawler.com/forum/electronics/284725-castle-creations-esc-tip-thread-brushed.html
You like V1.24, I like V1.28. I think the newer firmwares (after 1.28 ) are not as suited to crawler use.....at least, others here seem to have issues.
I had the same issue. You probably loaded beta 1.39 as i did. I went back to 1.38 and everything is peachy"thumbsup""thumbsup"
still no luk :( i let a friend take a look who knows alot more about electronics than me. He told me it may be heat dmg. im not sure if i should believe him, but since im still stumped ill take it to my lhs. thx again guys for trying to help. i appreciate it.
I can very much assure you there is no heat damage. Been professionally soldering for 11 years, not to mention I bench test everything before shipment.
It sounds to me like a radio issue. You should double check your programming on the radio and make sure it is mixed properly.
Also be sure that the red wires on the esc's are pulled out and only the BEC is powering the receiver. If you didnt do this, you can risk ruining the ESC'S. Make sure you have the rx plugs in the proper direction. The light tan wire is the siginalWhite wire. The brown is the negative/black wire. Castle likes to use goofy colors. Your esc's will never calibrate if theyre hooked up wrong.
To make sure each esc works of you need to, you can try this one esc at a time using the throttle channel to test with:
Plug in the battery. When the esc chimes, apply a tiny bit of throttle OR reverse until the lights stop blinking then hold it for a second. The esc should arm at that point, then when you give it throttle or reverse, the motor should move. This method is ONLY for testing an esc. It doesnt calibrate it.
Please let me know what firmware you have on it, and the settings. Also, post a picture of your receiver with all the rx pkugs in it
We will figure this out. I havent had a single issue with any of these so Im sure its just a radio issue"thumbsup"
I had similar problems . I thought I had ruined a couple of MM Pros mashing them together . After changing them back to an older firmware no more calibration issues . Thanks !!!
ok, iv reloaded 1.24 firmware. its not giving me the low voltage leds anymore, but it still will not calibrate. now when i try to calibrate it starts off with chime then counts my batt cells and does another chime and starts beeping and blinking red. i will post a picture of my receiver with all the plugs. i have servo and bec pluged into 1 front esc in 2 and rear esc in 4, and the red wires are pulled from both my esc's. these things r driving me nuts... lol
OK, I've reloaded 1.24 firmware. It's not giving me the low voltage LEDs anymore, but it still will not calibrate. Now when I try to calibrate it starts off with chime then counts my batt cells and does another chime and starts beeping and blinking red. I will post a picture of my receiver with all the plugs. I have servo and BEC plugged into channel 1, front ESC into channel 2 and rear ESC into channel 4, and the red wires are pulled from both my ESC's. these things are driving me nuts... lol
Did you even read this.... Castle Creations | FAQ: 1/10th Scale Products ?? I believe it will help you out.
BTW, how do you have a servo & a BEC into a single channel?
