I think here may be your problem. The expo on the TX should be at 0% to start. If it is at 100%, you are looking at barely moving almost all the way to the end the throttle then a HUGE jump at the end.
Try zeroing out all expo DR and reset your EPA to 100 foeward/reverse.
re calibrate the ESC go from there.
The rest is just precaution. I believe the EXPO is what is plaguing your set up.
Yes, the expo on the futaba is set to +100%.The throttle & brake curves are tottaly linear.The sensor cable is the one supplied with the tekin motor.Actually i bought a second one for testing purposes a week ago.
