1979crawler
Hi guys,
Iam facing a problem with my mamba max pro.I use it in a crawler set up with a brand-new tekin 13.5 turn sensored brushless motor with 12.5mm high torque rotor,brand new lrp 2s 65C li-po battery.So,whenever i try to overcome an obstacle with the brand-new sensor cable plugged in the car tries to overcome the obstacle in a very,very slow pace but the trigger is at almost half throttle.If i continue at the exact same time at full throttle the yellow and green leds are constantly on and the car stops.Having the trigger kept at full throttle if i lift the car on air it starts rolling very progressively in order to reach the full throttle speed (as it does),the yellow light goes off and the green led is know constantly on.If i disconnect the sensor wire and try to overcome an obstacle it is obviously glitcing at the very start of the throttle BUT as i continue pressing the throttle it overcomes the obstacle with extreme ease!!!I changed all the parameters using castle link such as deadband,punch control,max forward power,start power,smartsense brushless and sensor only mode but the problem is the same. Let me assure you that the battery is brand-new fully charged (8.4Volt).I tried some other 2s batteries,the same problem.Could someone tell me what is going on???
Thanks!!!
Thanks!!!
